what can cause compression loss?
Old Dec 2, 2002 | 10:54 AM
311's Avatar
311
Default what can cause compression loss?
i have a 98LS motor that had very low compression in 2 cylinders (like 50 or 60) It was boosted on for about 10K miles, daily 5lbs, on occassion 10lbs. factory sealed engine. I replaced the motor with a new one, and have since taken the head off the old one. I dont see any scaring of the walls, and everything looks okay. what could cause compression loss and how can I tell what the problem is without taking the pistons out?
Old Dec 2, 2002 | 10:55 AM
Spade's Avatar
Default Re: what can cause compression loss? (311)
Valve seals.
Piston rings.
Bent valves.
Bad headgasket.
Old Dec 2, 2002 | 10:56 AM
311's Avatar
311
Default Re: what can cause compression loss? (Spade)
how can i check for bad piston rings?
Old Dec 2, 2002 | 10:58 AM
Spade's Avatar
Pour a teaspoon of oil in through the spark plug hole before a compression check. If compression goes up, it is your rings.
Old Dec 2, 2002 | 10:59 AM
311's Avatar
311
can i still do a compression test with the engine out of the car?
Old Dec 2, 2002 | 11:08 AM
Spade's Avatar
Yeah as long as it is mounted properly.
Old Dec 2, 2002 | 11:49 AM
Turbo Powa's Avatar
Damn spade, everything I was about to say, you said. Oh well.
Old Dec 2, 2002 | 11:55 AM
Spade's Avatar
Default Re: what can cause compression loss? (Panda EK)
I've been around too long....
Old Dec 2, 2002 | 01:15 PM
311's Avatar
311
any other ideas?
Old Dec 14, 2002 | 12:18 PM
justinlude's Avatar
ok here is what you do Take the enginge out of you garage put it in the trash can like you did with my tranny and buy a new bumper for the eg asshat
iplayloudly
Nov 23, 2008 08:00 PM
turbociv910
Sep 9, 2008 05:26 PM
kornerk12
Jan 5, 2006 07:20 PM
Droppedatbirth!
15
Feb 2, 2004 06:36 AM
Soled Out
Sep 9, 2003 05:08 AM
