need help fast!
ok under the exhaust manifold?/
dont make fun of me for it..
its on the left side of the exhaust manifold mid way down looking at the motor from the front of the car its on the block not the trans
is it engraved or is it a code?? like a sticker
i found this
S1-1066919
[Modified by jdmb16ahybrid, 6:04 AM 12/2/2002]
i found this
S1-1066919
the s1-1066919 is your trans
the code is on the same flat piece that the motor code is on its also engraved
if you have a JDM motor, i assume you do, because the b16 dosent come with the 98 civic hatchback, there will be no VIN on the engine.
VIN numbers are an american thing.
so if they dont have a vin number - then how do you tell what year the motor is??
if the car is made in japan does that mean the motor is also??
the engine in your car, is not the engine that came with the car. it is aftermarket. now i highly dobut its a US motor, so there is no vin associoated with it. and unless your car is right hand drive, its an american car. no matter where its assembled.
now, to check the year of the engine, look above the header, you will see 4 stamps like circles. one of them will have the year in it. it will look like this 9|1 9|5 9|9 etc.
You got a first gen b16a head. There is really no way to actually tell what year the block is unless you bought the car new.
Edit: damn, im a little late
[Modified by 97hb, 12:51 AM 12/2/2002]
the entire engine is a 1990 first gen b16
