H&R springs
Old Dec 1, 2002 | 06:36 PM
lude69's Avatar
Default H&R springs
Those who have used H&R Sports, did u guys need camber kits? Also do they sag after time?
Old Dec 2, 2002 | 04:40 AM
beefpigs's Avatar
Default Re: H&R springs (lude69)
Curious too.
Old Dec 2, 2002 | 07:15 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Well I have around -2.2 degrees camber, but with proper alignment and frequent tire rotation, tire wear has been almost perfectly even for the past 20K+ miles since I installed the suspension back in February. I have not noticed any significant sagging since I installed it, either.
Old Dec 2, 2002 | 07:59 AM
Racer X's Avatar
I have them on my GSR and I am within spec on the back wheels and only -.8 degrees outta spec on the front. I have an Ingalls camber kit waiting to be installed but so far, the inside of the tires look fine. It's been almost half a year since the install.
Old Dec 2, 2002 | 08:22 AM
SMZ GSR's Avatar
i have the sports springs on my 98 GSR for a couple months now. front wheels started to tilt in a little, so just to save money on tires i plan on getting a camber kit soon.
Old Dec 2, 2002 | 08:35 AM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: H&R springs (PatrickGSR94)
How often do you rotate your tires?
Old Dec 2, 2002 | 09:54 AM
neo1z's Avatar
Default Re: H&R springs (FrostyDC4)
you will need a camber kit...one year after i have my kumhos, they are about shot....i give em 2 months.
just bought an ingalls front kit. you can do the washer trick in back.
Old Dec 2, 2002 | 11:50 AM
LRGsR's Avatar
Default Re: H&R springs (neo1z)
Just installed my H&Rs this weekend with a progress camber kit, camber is fine. The springs are AWESOME with my AGXs.
Old Dec 2, 2002 | 03:41 PM
Community Builder
I rotate about every 5K miles, give or take. That's what you should do for any car anyway. Your car will handle better w/o a camber kit and the H&R Sport springs. straight up 0 camber is bad.
[Modified by PatrickGSR94, 6:41 PM 12/2/2002]
Old Dec 2, 2002 | 04:53 PM
Tomakit's Avatar
I just got my car aligned (after 60k+ w/ hr sports) and my camber is at -2.2 degrees all around also. Tire wear is slightly greater. There appears to be some camber wear after 30k, and only on the rears. I rotate my tires every 10k or so.
However, after I first got my sus put on and had the car aligned, the camber was at -1.9 all around...so obviously the spring/shock combo has sagged/settled a little bit.
Old Dec 2, 2002 | 05:42 PM
SMZ GSR's Avatar
Default Re: H&R springs (LRGsR)
Cool, I also paired my H&R with AGX and yes they do handle really well
dohcvtecpower
Mar 21, 2006 11:40 PM
silva95teg
Jul 24, 2005 12:04 PM
hondaracin24
Aug 27, 2004 08:28 AM
LSTEG96
Sep 5, 2003 06:44 PM
ucb
Sep 22, 2002 12:57 PM
