baffled, what ECU does my friend have??
Old Dec 1, 2002 | 03:54 PM
1phatsol's Avatar
Default baffled, what ECU does my friend have??
ok the number on the side of the ecu is
37820-P72-A02-970-108377
does this mean he has the 94-95 P72 integra GSR ECU? on a 1st gen b16a? is this bad could it be hurting him?? makin him to run rich - any of you ecu junkies out there help him out thanks
BTW his name on this board is blackhatchb16
Thanks
Brian
Old Dec 1, 2002 | 04:05 PM
B_CRUZ!'s Avatar
Default Re: baffled, what ECU does my friend have?? (1phatsol)
Thanks
Brian
p72 gs-r ECU
Looose_R's Avatar
yea, hes got a gsr box, he should replace it with a chipped p28/08
Old Dec 1, 2002 | 04:08 PM
1phatsol's Avatar
Default Re: baffled, what ECU does my friend have?? (b20bastard)
what ECU is the P28/08? - where can he get one at?
Old Dec 1, 2002 | 04:16 PM
ejprimo's Avatar
92-95 civic vtec is a p28 and i think the p08 is the jdm version.
Old Dec 1, 2002 | 04:18 PM
1phatsol's Avatar
Default Re: baffled, what ECU does my friend have?? (ejprimo)
where can he get one at?? - is it plug-n-play, ie unplug old ECU plug in new one?
[Modified by 1phatsol, 1:18 AM 12/2/2002]
Old Dec 1, 2002 | 04:22 PM
Kamin's Avatar
no
if this is in an OBDI car or the first gen was converted to OBDI you need a p30 ecu, from a DOHC del sol vtec or JDM SiRII.
you can use a chipped p28 but thats alot of hassle, its easier to just get a p30
Old Dec 1, 2002 | 04:26 PM
eg6ajk's Avatar
Default Re: baffled, what ECU does my friend have?? (KAMiN)
here is a quick ID:
a quick pic in ID'ing a 5spd to auto ECU or just ECUs in general
Non-OBD (88-91)
PG7 : 88-89 Integra (D16A1)
PM5 : 88-91 Civic/CRX DX (DPFI D15b)
PM6 : 88-91 Civic/CRX SOHC Si (1.6l sohc)
PM7 : 89-91 Civic Si DOHC ZC (JDM EF3)
PM8 : 88-91 CRX HF
PR3 : 89-91 JDM B16A EF8/9
PR5 : 90-91 JDM Integra ZXi (1.6 sohc)
PW0 : 89-91 JDM/Euro B16A EF8/9 DA6-XSi (DOHC VTEC)
PR4 : 90-91 Integra LS/GS (b18a)
PS9 : 88-91 4 door civic EX Auto (sohc 1.6)
OBDI (92-95)
P05 : 92-95 OBD-1 Civic CX (D15B)
P06 : 92-95 OBD-1 Civic DX (D15B)
P07 : 92-95 OBD-1 Civic VX (D15Z1)
P08 : 92-95 OBD-1 Civic/CRX VTi/VXi (sohc vtec)
P0A : 94-95 OBD-1 Accord EX
PR3 : 92-93 OBD-1 JDM Integra RSi/XSi (B16A)
PR4 : 92-3 OBD-1 Integra RS/LS/GS (DOHC)
PR7 : 92-5 OBD-1 NSX
P13 : 93-95 OBD-1 Prelude Vtec (H22A)
P14 : 93-95 OBD-1 Prelude Si (non Vtec - H23A)
P27 : 92-95 OBD-1 Euro/Asian Civic (non-vtec 1.6l)
P28 : 92-95 OBD-1 Civic Si/Ex (sohc vtec d16z6)
P29 : 92-95 OBD-1 JDM Domani (sohc zc)
P30 : 92-95 OBD-1 DelSol DOHC Vtec Si/EG SiR
P39 : 92-95 OBD-1 JDM Accord SOHC VTEC
P54 : 92-95 OBD-1 JDM Domani/1.8l Accord (1.8L B18B DOHC)
P61 : 92-93 OBD-1 Integra GSR
P70 : 92-95 OBD-1 Domani (sohc vtec zc - no oil pressure sensor reading)
P71 : 92-95 OBD-1 Integra (sohc vtec d16a)
P72 : 94-95 OBD-1 Integra GSR
P74/75 : 92-95 OBD-1 Integra LS/GS
P76: 94-95 OBD-1 JDM Integra (sohc zc)
P84 : 92-95 OBD-1 JDM Civic ETi (VTEC-E auto)
P91 : 92-95 OBD-1 JDM Civic Coupe (sohc vtec 1.6)
OBDII (96-01)
P72 : 96-00 OBD-2 Integra GSR
P73 : 96-00 OBD-2 Integra Type-R (JDM & USDM)
P75 : 96-00 OBD-2 Integra LS/GS
P2N : 96+ OBD-2 Civic HX Coupe
P2P : 96+ OBD-2 Civic EX Coupe
P2T : 99+ OBD-2 Civic Si Coupe
P5P : 97-00 OBD-2 Prelude Type-S (JDM
in 88-91 ecus (PM6, PR4, PW0, PR3, PM7):
5spd = 000, 001, 002, A00, A01, A10, J00, J001, C01, C00
Auto = J51, J50, A50, A51, 901, A60, C50, C51, X30, A80
92-5 ECUs (P28, P30, P61, P72, P91, P08)
5spd = 000, 001, 002, 003, A00, A01, A02, C00, C01, C02, J00, J01, J02
Auto = J50, J51, 901, 902, C50, C51, C52, A50, A51, A52
96-00 ECUs (P2E, P2P, P2J, P72)
5spd = 000, 001, 002, 003, A00, A01, A03, C00, C01, C02, C03, J00, J01, J02, A11, C11
Auto = A70, A71, A72, A91, A92, C70, C71, C72, C91, C92
from the patterns we can learn the following:
first letter = country of orgin
J = Japan
C= Canada
A=USA
second digit, if 5, 7, 9 then ecu is auto usually
third digit denotes the version/variation
hope this helps
tealchief
Engine Management and Tuning
Feb 9, 2009 07:47 AM
G MoNeY Ej1
May 2, 2008 09:56 PM
hondaEg_808
Mar 25, 2008 11:10 PM
IGotVTECyo
Sep 4, 2005 08:46 AM
