Problems with Accord Antenna Installation - Pls Help!
Old Dec 1, 2002 | 10:47 AM
99_IntegR's Avatar
Default Problems with Accord Antenna Installation - Pls Help!
My antenna snapped off near the base, so I'm trying to replace it right now. I already removed the locknut, spacer, and rubber washer, but am having trouble removing the base of the antenna.
As seen in the pic, I can't remove that metal piece of the antenna. I tried pulling with pliers and unscrewing it, but it's totally stuck.
This is the part of my antenna that's snapped off.
Can someone tell me how to rip that metal piece off?
Old Dec 1, 2002 | 11:13 AM
Desslok's Avatar
Default Re: Problems with Accord Antenna Installation - Pls Help! (99_IntegR)
Open up the trunk, peel back the lining. There are 1 or 2 10 mm bolts that hold the base in. You remove it from inside.
Old Dec 1, 2002 | 11:45 AM
iam7head's Avatar
Default Re: Problems with Accord Antenna Installation - Pls Help! (sp)
yep, inside the trunk you'll see a pistol shaped power antenna.
is all there black and white, so have fun.
sobey
Mar 4, 2009 07:06 PM
mr devious illusions
Jan 20, 2007 01:14 PM
Crasian
Sep 3, 2005 07:08 PM
wagoneer
May 1, 2005 12:56 PM
Peter Griffen
Mar 20, 2003 04:48 PM
