How to remove the spedo from a 94 Accord Ex
Old Dec 1, 2002 | 08:45 AM
zzzhondazzz's Avatar
Default How to remove the spedo from a 94 Accord Ex
like the the whole thing??
Old Dec 1, 2002 | 06:56 PM
iam7head's Avatar
Default Re: How to remove the spedo from a 94 Accord Ex (zzzhondazzz)
this is for the 6th gen..but i think is kinda the same anyways.
there's two screws on top..take them out and
pull the black shore cover thing out.
then you'll see four more screw which holding down the the cluster.
tilt the guage cluster facing down and then unplug the greenish connectors.(3x)
that's all.
Old Dec 1, 2002 | 07:43 PM
EuRoBrO's Avatar
Yea what he said.
Old Dec 1, 2002 | 09:57 PM
Default Re: How to remove the spedo from a 94 Accord Ex (EuRoBrO)
The problem is where the a/c and heating buttons are at.
Old Dec 1, 2002 | 10:09 PM
iam7head's Avatar
OMG..you got a mini cooper or somthing? jk
do all the 94 accord have their speedo,tach meter located
in the center of the interior? LOL echo? mini cooper?
what are you talking about??
Old Dec 1, 2002 | 10:36 PM
MyBigNut's Avatar
Default Re: How to remove the spedo from a 94 Accord Ex (iam7head)
its quite a little different on the 5th gens.... the problem is the single big piece of dash that is in our car.
basically you have to take out the center console, so that you can take out the radio console, in order to get to the 2 screws under the heater controls. after that, you have to remove the cruise control buttons, the rear defroster and behind each of those is a screw.
then take out the 2 screws above the guages. pull the thing out, but be careful. you have 2 options.
1) manipulate it to get it out of your way and unplug just the electrical connectors.
2) take off the electrical connectors AND the hot/cold adjustment cable. the problem with taking off that cable is that its not hard to mess it up, and then your controls there will be messed up.
either way, its a PITA to get to. i hope youre not doing this in order to install some indiglo guages
good luck
AbbyDabs
Audio / Security / Video
Jun 29, 2008 09:21 AM
totomark
Oct 13, 2007 03:16 PM
A Tribe Called Honda
Mar 16, 2007 08:41 PM
brown94
Jun 9, 2006 06:17 AM
PleaseHelp
Jul 13, 2005 01:22 AM
