Would 5g Suspension set fit on the 4g prelude??
someone please tell me if it fits ASAP, the whole set as with the spring compresed and cap on, if not would just the shocks and spring fit the 4th gen??
Andrew
Yes, it fits fine. The whole shock/spring assembly is identical other than the spring rates and maybe damping rates. But the suspensions are completely interchangable. The only difference is that the front dampers on a 4th gen have little brackets to hold the ABS lines. If you use 5th gen dampers on a 4th gen, just zip tie the ABS lines.
Andrew
Andrew
You can also just knock the ring off with the ABS holders off the 4th gen shocks with a hammer, then attach them to the 5th gen shocks...that's what I did
[Modified by satan_srv, 6:41 PM 12/1/2002]
AsiAnVenOm
Aug 20, 2006 09:02 AM
bb6h22a
39
Aug 10, 2004 12:22 PM
