friend hit a curb...major steering problms
Old Nov 30, 2002 | 05:27 PM
98slvrcx's Avatar
Default friend hit a curb...major steering problms
my friend was messin around in a wendys parking lot doing power slides...he had the wheel turned to the right and slid sideways into a curb..the front left wheel hit the curb first and took most of the force, now when he drives it..the wheel does not straighten out after a turn it just stays there, it takes more effort to turn the wheel in either direction no matter what speed, and the wheels are no longer aligned, the car drifts to the left when holding the wheel straight...the car hit the curb pretty hard..is there major damage? or can this be an alignment-only problem? worse-case scenarios?
Old Nov 30, 2002 | 05:32 PM
Loco Honkey's Avatar
Default Re: friend hit a curb...major steering problms (98slvrcx)
Your answers lie in your local alignment shop. Most likely it's just an alignment issue; I've been ice racing Hondas for 5 years and have found Honda suspension mounting points to be VERY durable. But you never know... the alignment shop will be able to tell you for sure.
Old Nov 30, 2002 | 06:39 PM
98slvrcx's Avatar
Default Re: friend hit a curb...major steering problms (House of Boost)
anyone else?!
Old Nov 30, 2002 | 06:45 PM
flash2021's Avatar
anyone else?!
Old Nov 30, 2002 | 06:49 PM
ChiBoy's Avatar
Maybe he got lucky and just bent a tie rod. "Worse-case scenario" would be that he bent an LCA, or the cross member, but that's pretty unlikely.
He has to take it in. The shop will be able to tell for sure.
Old Nov 30, 2002 | 08:56 PM
ezekiel198's Avatar
Default Re: friend hit a curb...major steering problms (ChiBoy)
wheel knuckle.
Old Nov 30, 2002 | 11:36 PM
migs's Avatar
Default Re: friend hit a curb...major steering problms (ezekiel198)
Your alignment shop will be able to tell if the suspension has been tweaked. Id be surprised if the alignment COULD fix that. Were talking some bent suspension components.
Reebok4146
Honda Civic (2001 - 2005)
Aug 17, 2011 07:43 PM
teg_dc2
Mar 13, 2009 12:35 PM
pbizzlegsr
Mar 7, 2007 06:19 PM
skeg8
Mar 15, 2006 01:16 PM
dyases
Jun 10, 2004 08:56 PM
