need info on swapin h22a into 96 lx
hey i had ask for info on swap in a h22a4 into a 96 lx and but im going to ask again. The motor is a 98 sh no tranny was going to use a jdm one or us with lsd.
1. wiring herd was a biss
2. what ecu do u guys suggets
3. gouing to be na so for now need to make a lot of power
I've seen and help with a swap into a 95 but its obd1 mine is obd2 any help would help me alot thanks
try searching next time
ok see thats why i said mine was a 96 lx <U>OBD2</U> not <U>OBD1</U> and thos wring is for 94-95 not 96 -97 like mine and yes i have used the SEARCH thats why im asking for help but thank u tho. Like i said i have heard that theres more than just adding those wires because mines <U>OBD2</U> and so is the motor
but i thoght that u also had to do something with the motor becouse its obd2.The motor is a 98sh no tranny but im going to be using a 92-95 JDM LSD equiped. But have no clue on what ecu to use? and if i convert to OBD-1 will i have to do anything to the motor far as the intake or distributor. some one had said something about that but dont no if its true or not
hey any clue on what to do about the motor with the injectors distiubuter
and what ecu do u seject i go with?
the rest i am not sure bout.
if you go from obd2-1 can he just get a new ecu?
DA_teg04
May 24, 2007 06:58 PM
