koni red or yellow?
Old Nov 30, 2002 | 12:30 PM
AndrewJ's Avatar
Default koni red or yellow?
What are the differences and benefits of each? Does anyone rock the reds? The only difference that i can see that is listed is that the yellows are adjustable?
Old Nov 30, 2002 | 12:56 PM
Rob Dizzle's Avatar
Default Re: koni red or yellow? (AndrewJ)
spend some money and get the zeal b2's
by the time you add up the price of yellows and good sleeve type coil overs. you have yourself a nice high quailty/performance true coil over setup
btw, i have yellows and H&R springs
after driving zeal b6. i want to upgrade my suspension
search around here, you will find some usefull info
Old Nov 30, 2002 | 01:06 PM
BSQ's Avatar
BSQ
Both the Koni Reds and Yellows are adjustable. The Yellows are externally adjustable (via a **** on top of the shock). The Reds have to be removed from the car and compressed to adjust them. You can go to http://www.tirerack.com/suspension/k...ialvssport.htm for some information on both the Reds and Yellows.
Old Nov 30, 2002 | 01:14 PM
Broken Gearbox's Avatar
Default Re: koni red or yellow? (BSQ)
Koni Yellows
Old Nov 30, 2002 | 02:49 PM
2000GSR's Avatar
Default Re: koni red or yellow? (dEF juNKie)
koni yellows are way more stiffer than the reds, trust me big difference!
Old Nov 30, 2002 | 05:03 PM
Aaron M's Avatar
Default Re: koni red or yellow? (2000GSR)
yellows
Old Nov 30, 2002 | 05:57 PM
Solipsist's Avatar
Yellow
bigmike321321
Suspension & Brakes
Jun 22, 2008 04:10 PM
lazii_boi08
11
Jan 19, 2008 07:27 PM
TegoDC5
May 9, 2005 06:15 PM
2ndgent3g
Suspension & Brakes
Feb 2, 2005 11:31 PM
