Compression tested in the high 200's!
Old Nov 30, 2002 | 12:11 AM
94TealGSR's Avatar
Default Compression tested in the high 200's!
I just tested my compression with the $25 compression tester they sell at Autozone.
#1 - 260
#2 - 270
#3 - 280
#4 - 290
I'm running a B18C1 w/p73 pistons. (Not sure if they're USDM or JDM) I haven't really heard of anyone having compression this high before. I saw on c-speed racing's compression test how-to they show a car running 11.6:1cr and hitting 250. According to c-speed racing's compression calculator my car has either 10.8:1cr or 11.36:1cr depending on wether my pistons are JDM or USDM. Is my compression test numbers too high? Is that even possible? Anyone have any thoughts or input? I just rebuilt my motor about 7,000 miles ago, if it has any bearing on anything. Thanks in advance.
Edit: Fixed my links, and my spelling.
[Modified by 94TealGSR, 4:14 AM 11/30/2002]
Old Nov 30, 2002 | 12:30 AM
Downey's Avatar
Default Re: Compression tested in the high 200's! (94TealGSR)
wow, nice compression! i tested my stock cx motor and had 90,110,110,90. i guess my motor is a lil tired. ur numbers sounds about right.
Old Nov 30, 2002 | 12:52 AM
gsrvx's Avatar
New User
whoa, that's pretty crazy. my stock gsr motor did 210-210-205-210
Old Nov 30, 2002 | 01:36 AM
Quick Silver's Avatar
New User
what should be the compression for a 97 Ls?
Old Nov 30, 2002 | 06:47 AM
fanatic's Avatar
Default Re: Compression tested in the high 200's! (Quick Silver)
The higher the better.
Old Nov 30, 2002 | 07:09 AM
94TealGSR's Avatar
Not really sure why I posted here. Reposting in the tech forum.
Old Nov 30, 2002 | 10:12 AM
SIK IN DA HED's Avatar
New User
thats ridiculous. re-do your compression test... those #s are not normal. you might be cranking it too much. go to http://www.cspeedracing.com to get an idea of how to do it properly.
i20ar
Sep 17, 2005 12:48 PM
Nisif
Apr 12, 2005 09:13 AM
builtprelude
Jan 22, 2004 10:49 PM
94TealGSR
Dec 3, 2002 08:24 PM
stupidfast
Oct 20, 2002 03:50 PM
