need answer quick!!! I have OBD1 (1 o2 sensor) getting DC jdm 4-1 header...
Old Nov 29, 2002 | 02:43 PM
sleepycivix's Avatar
Default need answer quick!!! I have OBD1 (1 o2 sensor) getting DC jdm 4-1 header...
need answer quick!!! I have OBD1 (1 o2 sensor) getting DC jdm 4-1 header.. 2.5 carsound cat... Should I use the header o2 sensor and have them plug the cat.???
Old Nov 29, 2002 | 02:55 PM
MK Ultra's Avatar
Default Re: need answer quick!!! I have OBD1 (1 o2 sensor) getting DC jdm 4-1 header... (sleepycivix)
Do you have a GS-R or an LS?
The GS-R uses the O2 sensor in the cat, the LS uses one in the header. Do it however the factory did it and you'll be fine.
Actually, it really shouldn't matter either way.
Old Nov 29, 2002 | 03:00 PM
Default Re: need answer quick!!! I have OBD1 (MK Ultra)
i have type r... 96 JDM... i only use 1 02 sensor... will it be fine if i plug the carsound cat sensor housings and I use the header.?? right now.. i have dc 4-1 2" into stock cat. the dc 2" header i have now has no o2 housing
Old Nov 29, 2002 | 03:03 PM
Reid's Avatar
Global Moderator
Default Re: need answer quick!!! I have OBD1 (sleepycivix)
Yes.
Old Nov 29, 2002 | 03:04 PM
TypeR76's Avatar
install it on the header.
racekar
Oct 20, 2005 08:58 AM
r0guish
Jun 3, 2004 01:29 PM
solkid
Apr 9, 2002 09:33 AM
