Some LS/VTEC Build Up Pics
Old Nov 29, 2002 | 01:31 PM
DeL B18C SoL's Avatar
Default Some LS/VTEC Build Up Pics
Here are some pics of my bottom end build up:
[Modified by DeL B18C SoL, 10:33 PM 11/29/2002]
Old Nov 29, 2002 | 01:32 PM
VTEC-DA's Avatar
Default Re: Some LS/VTEC Build Up Pics (DeL B18C SoL)
Here are the two that didnt work.
Old Nov 29, 2002 | 01:43 PM
JDM92CX's Avatar
Default Re: Some LS/VTEC Build Up Pics (non-turbo2dr)
Oh your build up looks so damn fresh. Make's me want to build my motor right now. Good luck on it. BTW what head are you using and are you modding the valvetrain with what componets?
Old Nov 29, 2002 | 01:47 PM
civichopeful's Avatar
Default Re: Some LS/VTEC Build Up Pics (xJDM88EF9x)
What did you do to get the block so clean? I'm doing the same build up and pulled the motor last week, but it looked like crap. Leaky cam seal, leaky oil pan gasket, leaky this, leaky that. You know. I was just curious.
Old Nov 29, 2002 | 01:50 PM
craps_shooter's Avatar
hella clean!!!! all nice and shiney!!!
Old Nov 29, 2002 | 01:52 PM
Hammett's Avatar
mmm.. nice...
Old Nov 29, 2002 | 02:03 PM
oldB18EF's Avatar
Default Re: Some LS/VTEC Build Up Pics (Hammett)
very nice...
Old Nov 29, 2002 | 02:40 PM
tnbigdawg's Avatar
those pics bring back memories . theres nothing kooler than building an engine from scratch. id do it again if i had the money.
how are the clearances on those bearings?
and i cant tell in those pics, but do you have your cylinders honed to seat the new rings?
Old Nov 29, 2002 | 02:48 PM
Jawad.'s Avatar
how come it says b18b, and you can make out "b20" ?
Old Nov 29, 2002 | 03:00 PM
Hooch'n's Avatar
Default Re: Some LS/VTEC Build Up Pics (Jawad)
Old Nov 29, 2002 | 03:14 PM
Default Re: Some LS/VTEC Build Up Pics (tnbigdawg)
Yes the cylinders are honed(the first pic of the block is acually on the honing machine), I will try to upload some pics of the block being honed. The "B20" thing stamped on the block was just me being retarted.
[Modified by DeL B18C SoL, 12:15 AM 11/30/2002]
Old Nov 29, 2002 | 03:27 PM
Mrfirefox's Avatar
also wondering look at it
Old Nov 29, 2002 | 05:23 PM
Default Re: Some LS/VTEC Build Up Pics (Mrfirefox)
The stamp was put there because it's a 2.0 LS block now(84.5mm bore). Like I said just me f*cking around
Old Nov 29, 2002 | 05:38 PM
chameleon's Avatar
how much the block build alone cost ya? including the bore.. and also is that sleeved of just blockguard?
Old Nov 29, 2002 | 05:45 PM
Default Re: Some LS/VTEC Build Up Pics (chameleon)
Damn near all of the labor was done by me, except for Micropolishing / tear drop crank and balancing bottom end. The block is sleeved(Golden Eagle) and all parts coat around $2500.
Old Nov 29, 2002 | 05:56 PM
WingNutRacer98's Avatar
looks hella clean. thats what im fixin to do, but not sure if i wanna bore out to 2.0L, or just leave it at the 1.8L...? how much potential will be gained by boring out to 2.0L? especially in the scenario of a vtec head on the LS block, followed by probably a supercharger or turbo. i still havent decided on which one i want to go with after the build up.
Old Nov 29, 2002 | 06:23 PM
rainmanEK's Avatar
big strong guy
why?
eric
Old Nov 29, 2002 | 06:53 PM
deepnite's Avatar
Default Re: Some LS/VTEC Build Up Pics (rainmanEK)
DAMN !!
Old Nov 29, 2002 | 07:14 PM
kingpen's Avatar
Default Re: Some LS/VTEC Build Up Pics (deepnite)
PLEASE DO NOT QUOTE THE ORIGINAL PICTURE. Only joking. NIce engine can i have it?
Old Nov 29, 2002 | 09:22 PM
acydphryck's Avatar
$2500 for the whole short block with sleeves??? what a massive rip....and you're not even using honda OEM bearings...good luck with that. JE pistons with JE rings? looks like a 11.x:1 compression setup and nice sleeves. post dyno pics when setup is broken in...should be interesting to see how much whp you make with that setup. i'm sorry for flaming you with the bearings...i was just upset to see people put together LS/VTECs without using honda bearings...availability problems??? hope your setup turns out fine...
Old Nov 29, 2002 | 10:18 PM
ahcjar103's Avatar
Default Re: Some LS/VTEC Build Up Pics (acydphryck)
good luck with the setup
Old Nov 29, 2002 | 10:25 PM
I know a lot of people rip on them, but there working in my B18C build up with no problems. I thought around $2500 for everything was a cool price:
1.) 95' B18B LongBlock: $500
2.) GE Sleeves: $700
3.) JE Pistons: $500
4.) ESP Rods: $325
5.) Balance BE/Tear Drop Crank: $250
6.) OEM GSR Oil/Water Pump & Tensioner: $210
7.) ACL Bearings: $110
Old Nov 29, 2002 | 11:03 PM
SH0ck-D's Avatar
you should change your name from del b18c sol to del b18bc sol
heheh
D
Old Nov 29, 2002 | 11:08 PM
CHRIS 1.8's Avatar
Default Re: Some LS/VTEC Build Up Pics (SH0ck-D)
lol
Old Nov 29, 2002 | 11:52 PM
DCStreetHtch's Avatar
Default Re: Some LS/VTEC Build Up Pics (B16A1-EF8)
thats a clean *** block!
-Bryan-
