car is having trouble starting...
Old Nov 29, 2002 | 12:04 PM
integration's Avatar
Default car is having trouble starting...
recently, my battery died and i got a new one. It was starting fine for a day or two, but after a couple days, when i went to start my car, nothing would happen. I would try it over and over like 5 times, and usually on about the 5th try it would start. Sometimes it would start right up, and sometimes it would kinda struggle. Any ideas whats wrong? thanks!
Old Nov 29, 2002 | 01:24 PM
smallttocs's Avatar
Default Re: car is having trouble starting... (integration)
wtf is up with everyone's cars not starting up right??? ill go to helms when i get a chance bro. hopefully ill find something for you.
Old Nov 29, 2002 | 03:19 PM
Ricky Rojales's Avatar
Sounds like your ignition coil or ignitor needs to be replaced.
Old Nov 29, 2002 | 03:39 PM
Desslok's Avatar
You said your battery died and now it sounds like the new one is dying. I would get your alternator tested. Pep boys, autozone, etc will test for free. Also, check all your grounds.
Old Dec 1, 2002 | 05:55 PM
PnX-R's Avatar
Hmm.. If that was me.. I'd give the wires at the Battery, Alternator, and Starter Solenoid a little tug. And while I'm at that, I'd also check for dirty or loose connections..
But since you're saying that you might need a new Battery, I'd then test the Alternator with my screwdriver. I'd check to see if it's even creating its magnetic field.. And then with that out of the way, I'd go on and fix whatever needs to be fixed...
But what I think you should really do is have your Alternator tested.. Or you could do a search in the Tech Forum. There's a ton of questions and replies about the dreaded no start problem..
But other than that, good luck..
Old Dec 1, 2002 | 06:06 PM
nek0's Avatar
Default Re: car is having trouble starting... (PnX-R)
Your battery could be draining? With the car turned off, check the voltage with a voltmeter. Your battery cable isn't corroded is it? Wire corrosion will cause your car not to start up. Definitely get the alternator checked out by any auto shop...usually it's free
Old Dec 1, 2002 | 06:30 PM
Default Re: car is having trouble starting... (Nek0)
hmm...well, this problem seemed to fix itself. hasnt happen again in a couple days, hopefully itll stay this way. thanks for everyones suggestions
Old Dec 1, 2002 | 09:15 PM
SIK IN DA HED's Avatar
New User
if its a sign of power loss... its most likely your alternator.
Chris Teodoro
Mar 12, 2016 12:47 PM
lawlss
15
Sep 14, 2009 10:23 PM
jkalex05
Aug 31, 2009 10:31 PM
euroborn1
21
Jul 26, 2008 05:56 PM
Randomlude
Oct 7, 2002 09:47 PM
