eg rear lower control arms
Old Nov 29, 2002 | 08:34 AM
cnk600's Avatar
Default eg rear lower control arms
I have a skunk2 rear sway bar. But to install it I need to change my lower control arms. My question is, what oem rear lower control arms will accomodate this sway bar without compromising the factory alignment?
Old Nov 29, 2002 | 09:14 AM
eg6sir-s's Avatar
Default Re: eg rear lower control arms (cnk600)
i have not dealt with skank2 rear sway bar before...
this is what you can do...since you may have lost the instruction manual or it does not explain in detail what it is you need to do to make that badboy work...call your nearest skank2 distributor and ask them 'how to' or call skank2 direct.
http://www.skunk2.com
Old Nov 29, 2002 | 09:26 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Integra LCAs work fine.
SRR also has LCAs for 92-95 Civics and 94+ Integras.
Dunno what your deal is with the alignment, but ok.
Old Dec 3, 2002 | 11:44 AM
cnk600's Avatar
Default Re: eg rear lower control arms (SkyeC)
I am sure that the Integra LCA will work. But I am concerned with the camber change if any.
Old Dec 3, 2002 | 11:49 AM
HybridHatchC1's Avatar
?? just get some integra lcas man.
Old Dec 3, 2002 | 11:53 AM
Noe Kozz's Avatar
Default Re: eg rear lower control arms (HybridHatchC1)
---- Still lookin for the SRR LCA's for an eg on retail. I know they have them, but **** I want one.
boosteddb1_808
Aug 29, 2010 03:07 PM
08rampage
Jan 31, 2009 05:38 PM
spaceman00
17
Mar 16, 2007 11:31 AM
andyvaj
Mar 1, 2005 12:12 PM
