Do your Eg hatch red / clear tails fit GOOD??
Old Nov 29, 2002 | 07:14 AM
Fuster_Cluck's Avatar
Default Do your Eg hatch red / clear tails fit GOOD??
I ordered a set of the red / clear tails off ebay and just installed them.
I will post some pics in a few minutes but mine are not fitting that great.
The outer ones when tightened down are sitting too deep on the car. Not really a problem since I will add washers underneath the light bolt which will allow the tail to come out further to amtch the exterior panels.
Drivers side outer tail light: Opening for the small bulb on the red reflector part is too small for the bulb to get in I probably can dremel the plastic out a little bit, but I shouldn't have to do this
Both the inner tails are sitting flush on the car, but the gaps along the top edge are kind of big as well as towards the inside next to the license plate. The gap along the bottom is perfect, but you can't hardly see it unless you get down low to the ground
So far I have to give my red / clears a
I'm going to e-mail the guy I purchased them from and show him pics. Maybe he can get me a new outer drivers and both inner tails
I just would like to know how your red / clear tails fit and where you got them from? If ebay, please say who the person was. Thanks!
Here are the pics:
[Modified by Hybrid93Hatch, 4:38 PM 11/29/2002]
Old Nov 29, 2002 | 07:23 AM
KRiS1's Avatar
Default Re: Do your Eg hatch red / clear tails fit GOOD?? (Hybrid93Hatch)
oops
[Modified by POS Hatchback, 8:24 AM 11/29/2002]
Old Nov 29, 2002 | 07:24 AM
KRiS1's Avatar
mine seem to fit pretty good
Old Nov 29, 2002 | 08:12 AM
tommyboy's Avatar
Mine fit great.
Old Nov 29, 2002 | 08:55 AM
chameleon's Avatar
Default Re: Do your Eg hatch red / clear tails fit GOOD?? (tommyboy)
good fit here, they aint perfect.. only OEM is and ever will be.
Old Nov 29, 2002 | 09:01 AM
jEE's Avatar
jEE
Default Re: Do your Eg hatch red / clear tails fit GOOD?? (chameleon)
clean ride
Old Nov 29, 2002 | 10:15 AM
zRd#1's Avatar
Default Re: Do your Eg hatch red / clear tails fit GOOD?? (visionism0)
my friend has them and they have a bunch of water in them
Old Nov 29, 2002 | 10:38 AM
MrJasey's Avatar
Default Re: Do your Eg hatch red / clear tails fit GOOD?? (POS Hatchback)
daymn POS hatch your hatchie looks nice and clean
Old Nov 29, 2002 | 10:43 AM
Default Re: Do your Eg hatch red / clear tails fit GOOD?? (zRd#1)
I would rather have that problem then fitment problems.
Just get some clear all weather silicone and go to work on the seams
Problem solved
Old Nov 29, 2002 | 12:15 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
I was going to show the picture again, but it's too dang big. It is nice though, very clean
Old Nov 29, 2002 | 12:48 PM
ChiBoy's Avatar
I had the same problem. Came in a no name box packed in Tiwanese (sp?) newspaper.
Old Nov 29, 2002 | 01:33 PM
JDM92CX's Avatar
Default Re: Do your Eg hatch red / clear tails fit GOOD?? (ChiBoy)
Doesn't seem bad!
Old Nov 29, 2002 | 01:44 PM
Soulless's Avatar
Default Re: Do your Eg hatch red / clear tails fit GOOD?? (xJDM88EF9x)
What color is that car POS hatch?? it looks nice
SnekyDevilz
May 4, 2010 07:55 AM
VTECME
19
Jul 1, 2007 12:16 PM
gribbs
Jun 18, 2002 01:10 PM
Jonathan_ED3
15
Apr 14, 2002 09:22 PM
