civic radiator into integra?
Old Nov 28, 2002 | 08:58 PM
JeremyL's Avatar
Default civic radiator into integra?
could i put that half sized civic rad into my 94 LS? would it bolt in? wold the reduced size hurt my cooling efficiency? the reason i ask this is because this free up a ton of space to put my IC in and i know exactly how i want to mount and pipe in and having a radiator half the size would allow me to do this perfectly
i would have it flipped backwards from what you see in the pic so that small pipe sticking straight out would be towards the block and the pipe that angles would be down and toward the R fender
Old Nov 28, 2002 | 10:27 PM
MugenGTR's Avatar
Default Re: civic radiator into integra? (JeremyL)
it's not a direct fit. you have to custom mount it. i remember there's a single radiator from another car thas almost a perfect fit, jus cant remember wat car it was, haha
Old Nov 29, 2002 | 01:21 AM
slomob18b's Avatar
i think i remembering reading that its not good to have that small radiator if you have AC in your car...maybe somebody else can clarify this
Old Nov 29, 2002 | 05:01 AM
Adriano's Avatar
Default Re: civic radiator into integra? (slomob18b)
You shouldn't have any overheating problem. 90% of civic owners who put b-series engine keep their half sized radiator.
Old Nov 29, 2002 | 06:40 AM
mr_mbuna's Avatar
Default Re: civic radiator into integra? (brryder)
No overheating with a half-size radiator on a boosted LS? Raise the heat, lower the cooling and still no problems eh? I'd be wary.
Ben
Old Nov 29, 2002 | 07:53 AM
Audi A4's Avatar
Default Re: civic radiator into integra? (mr_mbuna)
Ben
well when i was boosting, i would over heat, but also te fmic was blocking the radiator. but as long as ur not blocking that one radiator you should be alright.. ask people with sohc turbos what they think
Old Nov 29, 2002 | 10:37 AM
94TealGSR's Avatar
I'd be wary.
Old Nov 29, 2002 | 10:59 AM
tony4311's Avatar
Default Re: civic radiator into integra? (94TealGSR)
I'd be wary.
Old Nov 29, 2002 | 07:32 PM
JeremyL's Avatar
Default Re: civic radiator into integra? (tony4311)
the way i would have it setup would be to have the IC to the right of the radiator so that the IC doesnt block the rad and the rad doesnt block the IC, both can get enough airflow, i really cant see any other way to mount the IC without freeing up some radiator space. Mounting it right behind the bumper for me would mean way too much charge piping and it would block some airflow to the radiator
im thinking maybe if i mount some slim line fans one on each side of the radiator that would help airflow a lot
Old Nov 29, 2002 | 11:42 PM
mos's Avatar
mos
Theres different depths to those half width radiators. Most people with the shallow ones say they are fine, but if you are worried just get a deep one. Or a fancy aftermarket one would work too.
Old Nov 30, 2002 | 02:17 AM
GZR4DR's Avatar
Default Re: civic radiator into integra? (mos)
Just get the del sol vtec radiator. Its dual core. Or go aftermarket.
CasperX
Dec 18, 2007 02:34 PM
JDM turbo DC
Mar 1, 2006 12:41 PM
zeroz
Sep 11, 2005 03:40 PM
cloven
Jun 27, 2005 04:36 AM
i3oricua
Apr 9, 2005 07:43 PM
