coilovers without shocks?
You know the bigest thing is what coil over system you use ... GC is a good one because Eiboc makes the spring for them ..... Something like max speed and over cheap stuff does not ride as good....... It comes down to you pay for what you get and that is the truth when it come to coil over systems !!!!!!
i have neuspeed sport springs with stock shocks/struts, it rides OK, but my friend has GC with tokico blues and it rides SO MUCH better. if u have the money get the better setup, if not, then the ride is OK. u can always upgrade the shocks later if u have to
So the shock's would blow because the extra pressure.. mainly speaking, i'd need to replace the shock's with some sport shocks? what brand would you reccommend? gotta be carefull with the whole shock/spring deal because it is like the "personality" of the car. Ground controlls? how much can i get some for? and lastly, what does it take to install all these goodies
after a few days the shocks will be blown and you will bounce like crazy.
yah, see i dont want to "open a can of worms" as the saying goes and have to start replacing all kinds of things after they fail.. i'd much rather have exactly what's needed and then do it. Will i have to bother with "camber readjustment kit"'s if i do lower my car?
if you really just want to spend the least amount of money possible get some Eibach pro springs. the drop is about 1-1.5 inches and wont effect your struts unless they already suck. camber will be ok and the rest of the suspention will be fine. just remember to have the toe checked. about 100 bucks. if the toe is off it will eat through your tires faster than any amount of -camber.
i have ground control and tokico blues.. it's pretty low and has been like this for over 3 years.. rides great, handles great.
Good Luck
