How to Store Drag Radials over Winter?
I have a set of Nitto DR's that are almost 2 years old, used only at the track. They are sitting in my garage now but what would be a good way (with the age of the tires) to store them this winter. I was thinking putting some VHT on them and putting them in a tied up garbage bag? I just don't want them to dry rot and if possible I wanted to soften them up a little over the off season.
Anyway, anyone have any tips on what to do?
Well here is what mickey thompson say's
1. Remove the tires from the car or jack the car up to remove the load.
2. Drop air pressure to 5 pounds.
3. Keep the tires away from direct light (sun or fluorescent). It is best to keep tires covered.
4. Keep tires away from electric motors I.E. furnace, air compressor, etc. These create OZONE, which will damage the tire.
5. Mickey Thompson suggests that you keep tires away from extreme high and low temperatures.
6. Do not use any chemicals on the tires. To clean them use a mild detergent and water. Rinse well. Do not clean the tread surface.
By following these simple precautions you will get the best service from your tires. If you experience inconsistent 60' & 330' times the next season, it's probably time to replace the tires
Those recomendations should work for drag radials also. Jason
imzjustplayin
Jul 10, 2008 06:47 PM
