Problems with tranny mount for 93 hatch when converting to 5-speed.. Help me out..
Old Nov 28, 2002 | 06:26 PM
phatz's Avatar
Default Problems with tranny mount for 93 hatch when converting to 5-speed.. Help me out..
Hi, My first post.. Not my first problem
I got a 93 hatch. I swapped in a 5-speed motor and converted to auto. Everything is complete except the tranny mount.. I am using a 5-speed mount. The first time I bolted it up with the mount, the motor sat on an angle.. My local mecahnic told me I need to weld a 1.5" spacer on the mount. Anyways I got the mount for free so I welded a 1.5" spacer on it.. Now the mount does not seem to line up.. Its not lining up horizontally.. Has anybody ever had this problem..
Sorry if I may sound stupid..
Old Nov 28, 2002 | 07:15 PM
phatz's Avatar
Default Re: Problems with tranny mount for 93 hatch when converting to 5-speed.. Help me out.. (phatz)
Well has anybody swapped a dx 5-speed motor into the hatch? What did ya do with the tranny mount?
Old Nov 28, 2002 | 07:52 PM
Soulless's Avatar
the shop i helped did a d16a auto to b16a maanual, and they had to move the mount back i believe, the autos mount is to far forward.
Old Nov 28, 2002 | 08:46 PM
phatz's Avatar
Default Re: Problems with tranny mount for 93 hatch when converting to 5-speed.. Help me out.. (Soulless)
Well I am having the problem of the mount being to far back.. the mount needs to be taken up about 1/2 inch to 3/4 an inch forward to the front on the car.. I dunno.. Nobody can give me a 100% answer..
Old Nov 28, 2002 | 09:01 PM
CVC9216's Avatar
The mount bracket on the frame is different. The manual one is forward and sticks straight out instead of up. the part is available from dealers and must be welded on.
Old Nov 28, 2002 | 10:00 PM
TurboTeG4's Avatar
Default Re: Problems with tranny mount for 93 hatch when converting to 5-speed.. Help me out.. (CVC9216)
I fabricated my own tranny mount for my auto to standard out of steel , its probably better then the factory ones
Old Nov 29, 2002 | 06:43 AM
phatz's Avatar
Thanks for the help..
So either
a.custom make a motor mount
b. drill out the mount on the auto frame and weld on a 5 speed bracket..
aznjay510
Jul 6, 2007 01:50 PM
KickStart2323
Mar 8, 2007 06:23 AM
hothotpete
Nov 22, 2004 11:12 PM
