Which crank pulley and belts to use for JDM H22?
Old Nov 28, 2002 | 06:05 PM
red92s's Avatar
Default Which crank pulley and belts to use for JDM H22?
Is net necessary to switch my USDM crank pulley (f22) onto the JDM H22 when doing this swap? I have heard that there is a slight difference between the belt ribs or something along those lines. Also, can I use the USDM f22 accessory belts, or should I get the H22 ones? I guess I should just buy new ones. . .better than sorry? Thanks in advance!
Old Nov 28, 2002 | 09:54 PM
fastludeh22's Avatar
Default Re: Which crank pulley and belts to use for JDM H22? (red92s)
i'd use what ever crankpully was smaller and lighter...on my girls 92 integra, i used a crankpully off a 91, it was about 1/2in or so smaller and you could feel the weight difference. use what ever belts corespond to the pully you use, but buy new ones eathier way
Old Nov 29, 2002 | 02:15 AM
DarkJedi's Avatar
Default Re: Which crank pulley and belts to use for JDM H22? (fastludeh22)
use the jdm p/s pump and alternator, swap out the AC pulley, you will need to remove the 1 nut holding it (on a f22) and use a gear puller, then use the belt that came with the jdm engine.
C2K_TB_TEC
Apr 17, 2012 07:09 PM
speedfreak44
Feb 9, 2010 10:44 AM
steven100100
Oct 9, 2008 11:17 AM
zracer240
Jan 20, 2006 07:29 AM
mdjplay
Jan 9, 2003 03:13 PM
