Removing Front bumper need help ASAP
Old Nov 28, 2002 | 05:36 PM
kshymkiw's Avatar
Default Removing Front bumper need help ASAP
I am trying to remove my front bumper on my 89 CRX Si. I got all the bolts (i think) underneath and in the wheel wells. and i go to pull it and it is catching on something where the headlights are. Do i have to remove the headlights to take off the front bumper. I am prepping the bumper for a FMIC so i need it off
Old Nov 28, 2002 | 05:55 PM
kshymkiw's Avatar
Default Re: Removing Front bumper need help ASAP (kshymkiw)
someone ahs to know
Old Nov 28, 2002 | 05:58 PM
wanttorace's Avatar
just take off the bumper lenses and there will be two bolts do that on the other lenses and than in the fender there are two screws take those off than it should come off
Old Nov 28, 2002 | 05:59 PM
kshymkiw's Avatar
Default Re: Removing Front bumper need help ASAP (jjd493925)
ok thanks
Old Nov 28, 2002 | 06:01 PM
wanttorace's Avatar
no problem
Old Nov 28, 2002 | 06:38 PM
crxforum's Avatar
1 - Remove the two screws from the side of the corner marker light and carefully pull the light forward, towards the front of the vehicle. It will be tight because of two clips that push into a mount, but it will come out, just pull slowly. Once it comes out, unclip the wires for its light. Of course you do this for both sides of the car
2 - Remove the screw that is inside the corner marker opening.
3 - Remove the two screw that attach the bumper to the fender.
4 - Remove the three screws that attach the top of the bumper cover to its support bracket. Sometimes these screws are very hard to get too, if so you may leave them alone. This will require the removal of the bumper cover and its inner support beam as a whole. Its actually usually easier anyway.
5 - Remove the turn signal lights. Only the outside screw needs to be removed.
6 - Jack the vehicle up (safely). There are 3 plastic plates, one center and one on each side, that attach to the bottom of the bumper. There are also a few screws that attach the bumper to the car. Just use common sense and you'll figure out which ones need to be removed. No pictures. I took the plastic underside plates off my car years ago and never put them back on.
7 - Gently pull the sides of the bumper cover outward so that they can slide forward.
8 - If removing the bumper cover and its support beam as a whole then you will need to remove the two bolts that attach the beam to the car. They are located inside the turn signal lens opening. It will feel like the whole bumper will fall but it is actually help in place by two small tabs.
9A - If you are removing just the bumper cover you can now carefully pull it forward and remove it.
9B - If removing the support beam with the cover attached then you'll need to lift the front of the bumper 1/4 inch before pulling forward.
Old Nov 28, 2002 | 07:16 PM
kshymkiw's Avatar
Default Re: Removing Front bumper need help ASAP (crxforum)
I got it thanks for the help guys
7panget
10
Apr 22, 2009 06:16 AM
innes887
Jun 14, 2007 11:47 AM
97LXAcc0rd
Jul 28, 2005 09:20 PM
azian21485
May 11, 2004 08:13 AM
2k1_ITR_0736
Feb 13, 2003 03:57 AM
