Help ID this Carsound Cat!
Old Nov 28, 2002 | 03:35 PM
Rdriven's Avatar
Default Help ID this Carsound Cat!
A couple months ago I bought a carsound cat from the HT classifieds, in the ad the guy said that it was used with a jdm 4-1 header and stock exhaust, he was also selling various itr parts... He said that the cat was purchased from IPS Racing, which I believe, the cat has nice welds and seems to be put together very well.
The problem is that I measured the cat and it seems to be 2.5 in and 2.5 out
and also that the cat is a #94000, which I have searched and never found any info on. Last thing: the cat measures 16 and 3/4 inch in length is this the correct length for my 01 ITR?
Will I have to get a flange welded on to my stock exhaust for this to work.
Please help and give any info, and yes I have used the search function many times on this subject...just no answers.
Old Nov 28, 2002 | 04:22 PM
scottishbastard's Avatar
Default Re: Help ID this Carsound Cat! (Rdriven)
Hey,
The cat more than likely is the 94006. I am not sure of the correct length the cat should be, but I will measure my cat tomorrow if that will help you. The cat will measure 2.5" in/out because that is the outlet diameter of the JDM ITR 4-1 header. It will also bolt up to the stock exhaust flange, but there will be a nasty bottleneck at this connection. I would have a muffler shop or SMSP make you a smooth transition flange to go from 2.5" to 2.25". Also, remove the bottleneck at the flange(s) from the b-pipe to the rear section. Your next step is to find a "reputable" muffler shop in your area. That is the key.
Hope your Thanksgiving was good.
HTH. Later
Old Nov 28, 2002 | 04:45 PM
Rdriven's Avatar
Default Re: Help ID this Carsound Cat! (scottishbastard)
Thank for reply, Im hoping that the length of the cat is correct...I only bought this cat to use in the cold months ( I hate aftermarket exhausts in winter, very dirty...too cold to wash car that often) I wanted it to go with stock exhaust unmodified, but now that I have 2.5 in/out I think I will go ahead and send SMSP an IM and get the flange...I probably need it anyway.
Thanksgiving
Old Nov 28, 2002 | 08:43 PM
No problemo.
Good choice. Bottlenecks Remove the rear section bottleneck at the flange and you will be set. Maybe get a new rear section for the track or street.
Glad I could help.
Old Nov 28, 2002 | 09:20 PM
Mike M's Avatar
Founding Member
Same cat everyone is using same inlets and outlets. Your all set as long as your using a Japanese market Header
shhh151
Aug 4, 2004 02:32 PM
lilmoney145
Feb 14, 2003 01:16 PM
SIK IN DA HED
Sep 6, 2002 01:10 AM
