Removing center console
Old Nov 28, 2002 | 09:03 AM
TypeRPinoY's Avatar
Default Removing center console
can anybody tell a nooB how? i took off my shift **** and took the six screws out and ive been pulling and pulling but the thing still wont come off...can anyone enlighten me? thanx
Old Nov 28, 2002 | 09:07 AM
yellow blur's Avatar
Default Re: Removing center console (TypeRPinoY)
6 screws?
You should only have to remove 4 of them. The 2 of them that are located right under the e-brake button under the cover, and the 2 of them that hold the console in, on each sides near the rear towards the rear ashtray. Then just slide it up.
If you're talking about the cig lighter and change/ashtray you have to remove the most outer two on each side of the console, then you have to remove the ash tray, take out 3 screws behind that, and then pull it out. You will see 2 more screws after that. So that's a total of 7 screws.
Old Nov 28, 2002 | 09:09 AM
Cosworth's Avatar
Well, here's how many screws you need to remove...
2 - screws by the e-brake handle (under plastic cap)
2 - screws by the ash-tray in the center console
then, 2 screws on the side of the front console (the one that's attached to shift-**** cover)
finally, 2 screws <u>hiddne</u> behind the front ashtray and front console panel.
Yup, you have to pull out the whole ashtray and cigarette lighter housing.
Old Nov 28, 2002 | 09:11 AM
TypeRPinoY's Avatar
Default Re: Removing center console (yellow blur)
im trying to put in a jdm shift boot so do i have to take out the whole thing or just the ashtray part?
Old Nov 28, 2002 | 09:28 AM
If you're trying to install a shift boot you're going to have to remove your ARM REST and CENTER CONSOLE. Those are 2 different pieces.
Old Nov 28, 2002 | 01:36 PM
machgo5go's Avatar
I got the instructions by doing a search:
https://honda-tech.com/zerothread?id=247376
Old Nov 28, 2002 | 05:45 PM
TypeRPinoY's Avatar
Default Re: Removing center console (machgo5go)
i figured it out...thanx a lot tho
Old Nov 28, 2002 | 05:46 PM
Leo's Avatar
Leo
How come my JDM boot has a seam that goes up the back?
Old Nov 28, 2002 | 06:14 PM
skafia's Avatar
25 Year Member
Default Re: Removing center console (ITR 01-0166)
My picture is better:
Old Nov 28, 2002 | 06:36 PM
machgo5go's Avatar
what do u mean?
Old Nov 28, 2002 | 07:07 PM
B2FiNiTY's Avatar
Here's my how to on shift boot install:
1. Pop the rectangle cover under the handbrake. Unscrew the 2 gold screws.
2. Unscrew the armrest box (unscrew 2 screws on the bottom/rear of the box) and remove
3. pull out the ashtray completely (unscrew 2 screws inside)
4. pop out the ashtray holder/cig lighter assembly
5. Unscrew 2 screws holding onto the shifter boot console and 2 more screws on the sides
6. Unscrew the shifknob
7. remove the shifter boot console and flipped it over (unscrew the 2 screws)
8. Install the new boot
Old Nov 28, 2002 | 07:26 PM
Leo's Avatar
Leo
what do u mean?
There is a seam in the middle, between the red stitches. Got is from JDM Hondaparts. I guess its for the Civic Type R because the bracket it came mounted on was wrong. I had to put it on the stock bracket. Did i get screwed or what?
Old Nov 28, 2002 | 07:41 PM
machgo5go's Avatar
I can understand u may got screwed by sending u one with wrong bracket because mine fit right it from these guys without any hassle, but I thought all the boots are same?
Old Nov 28, 2002 | 07:47 PM
Leo's Avatar
Leo
It's the same bracket as the one pictured in my last post, which is not the same bracket as the stock. The bag it came in was sealed with the Honda tag, with just the part # cut off. I'm confused. It fits right on the stock bracket, but why is there a seam down the back. Now i'm aggravated
Old Nov 28, 2002 | 07:51 PM
machgo5go's Avatar
U got any pic i can see?
Old Nov 28, 2002 | 07:54 PM
Leo's Avatar
Leo
I have a digi cam but don't know how to get the pics up. I'm ready to go buy a new boot or call JDM Hondaparts and see what's up. It looks good and fits good, but why that seam? Nobody else's looks like that.
Old Nov 28, 2002 | 07:57 PM
machgo5go's Avatar
I signed up for free in imagestation.com and uploaded my pics. After that, follow the HT's Image post directions.
graham_ott
Honda Civic (2001 - 2005)
Jun 29, 2015 10:12 AM
retrograde
Honda Fit
Mar 8, 2008 08:03 PM
JumboJoe
Audio / Security / Video
Jun 10, 2003 04:46 AM
allmotorls95
Jan 14, 2003 10:15 AM
Judah
Nov 21, 2001 08:22 AM
