post your aftermarket springs.
Old Nov 27, 2002 | 07:13 PM
will's Avatar
Default post your aftermarket springs.
i just want to see what everyone have, and how they like them.
does anyone run ITR springs on their non-type r? comments on it?
thanks
Old Nov 27, 2002 | 07:26 PM
AlphaKennyWun's Avatar
Default Re: post your aftermarket springs. (will)
Eibach prokit - sport springs. alright handling. No camber problems. rear appears lower to me but Koni yellows fixed that. I would like less body roll i.e. stiffer in rear, a stiffer sway bar should fix it.
I had:
Neuspeed race - race springs. very good handling. unforgiving over potholes. too low. sold for $50
Weapon r sleeve coil over- good spring rates. good handling. too much clank and chatter over bumps. kinda cheap build quality. Just threw them away
Old Nov 27, 2002 | 07:36 PM
passinUby's Avatar
Default Re: post your aftermarket springs. (SO3Burner)
h&r race springs...switching to some teins in a couple of months though
Old Nov 27, 2002 | 07:52 PM
Understeer's Avatar
Default Re: post your aftermarket springs. (passinUby)
H&R Sport Springs. Lowered 1.75" and 1.5" in the rear. 276lbs/ft spring rates.
Good for street use. No camber wear, but need an alignment done.
I'm happy with the springs.
Koni Yellows will be paired up with them soon.
Old Nov 27, 2002 | 07:59 PM
GreenD's Avatar
h&r sport - itr spec and agx's going in friday
Old Nov 27, 2002 | 08:42 PM
Honda Hick's Avatar
I got Eibach Sportlines. I like them alot but the back is higher than the front. I think this is due to me using 89-91 civic struts. Not sure because alot of guys have used them because they are really similar.
Old Nov 27, 2002 | 08:56 PM
garados's Avatar
standard ground controls. Paired up with my illuminas, they're great. I'm at the highest setting now (215/45/17 tires ) which is about .25-.5 inches lower than stock.
p.s. My grammar, word choice, spelling, and sentence structure suck.
Old Nov 27, 2002 | 09:42 PM
mugenracer's Avatar
Default Re: post your aftermarket springs. (garados)
Apex race springs with mugen sport shocks, lowered approx 1.75"
Old Nov 27, 2002 | 10:28 PM
will's Avatar
garados:
do you have a pic of your car? im a sedan owner also. :D
Old Nov 27, 2002 | 10:39 PM
GSRaCeRbOI's Avatar
Eibach Sportlines springs along w/ Koni Yellows.. front is on standard perch setting.. rear is on 1 notch up setting... also have ST sway bars, Neuspeed strut tower bars, 16" SSR's wrapped in Dunlop SP Sport 9000.... IMO my car handles really well.. hardly any body roll ..grips really well on corners, turns, S-curves.. the ride isn't harsh and its low but not TOO low that its undriveable everywhere...
as for comfort my ex gf would say it was too harsh (she drove a stock prelude) a ride but I like it and my friends never complained...
Old Nov 27, 2002 | 11:45 PM
Aaron M's Avatar
Default Re: post your aftermarket springs. (GSRaCeRbOI)
do you have pix of your car, id like to see that setup with the SSR's
Old Nov 27, 2002 | 11:49 PM
hitop's Avatar
Default Re: post your aftermarket springs. (SilverB18C1)
Eibach Pro-Kit mounted on Bilsteins. Just installed them this past weekend too, what a sweet ride.
Old Nov 28, 2002 | 12:04 AM
GSRaCeRbOI's Avatar
Default Re: post your aftermarket springs. (hitop)
if my parents or friends get me a digital camera for X-mas I'll have pix of it.. otherwise no because my dumb *** friend lost my Sony F-707 on our ski trip
Old Nov 28, 2002 | 12:24 AM
NuclearB18B's Avatar
eibach sportlines...i like them, but a little too low for me
Old Nov 28, 2002 | 12:33 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: post your aftermarket springs. (ha illuminato un)
skunkworks coilovers (yes, skunkworks, old *************) on koni yellows.
DONT GET SKUNK COILS! too bouncy for anything.
Old Nov 28, 2002 | 12:40 AM
Ronin Integra8's Avatar
Default Re: post your aftermarket springs. (dLo GSR)
where were you a week ago, before i bought my skunk coilovers? yea thanx alot
Old Nov 28, 2002 | 01:20 AM
Pat's Avatar
Pat
Default Re: post your aftermarket springs. (Ronin Integra8)
I have H&R OEs , kinda like ITR springs. Stiffer ride but not harsh at all, noticeable reduction in body roll (w/ Bilsteins). And I've never bottomed out or scraped!!
Old Nov 28, 2002 | 07:04 AM
SubieDude's Avatar
Default Re: post your aftermarket springs. (Pat)
skunk2's on stock shock...and they dont ride as bad as everyone says
Old Nov 28, 2002 | 07:22 AM
jabroni95gsr's Avatar
Default Re: post your aftermarket springs. (WhiteS2)
I have the exact same setup. Its great.
Old Nov 28, 2002 | 08:10 AM
B94Cast's Avatar
Default Re: post your aftermarket springs. (jabroni95gsr)
I am running Sprint Performance Springs with SPC camber kit... Like the setup quite a bit! Still getting used to lowered car hazards though...
Old Nov 28, 2002 | 08:18 AM
PHAT-INTEGRA's Avatar
Default Re: post your aftermarket springs. (B94Cast)
Im running Eibach Sportline (1.7" drop), Skunk2 Camber kit with Stock shocks. I love them except I scarpe the bottom a little over the bumps. Also I get a little tire rup if I go hard into the cornors.
Old Nov 28, 2002 | 09:08 AM
IC x Prince's Avatar
New User
Default Re: post your aftermarket springs. (PHAT-INTEGRA)
ground controls...(eibach sprins) very good for daily driving
Old Nov 28, 2002 | 04:38 PM
GSRaCeRbOI's Avatar
is SPC the same as "Specialty Products?" or are they different? I went to a local rim/tire shop and inquired about a camber kit for the front.. they wanted like $400+.. as I was walking out the door.. I was like (verbally) let me think about it...(thinking) yeah right...
Old Nov 28, 2002 | 05:28 PM
threatcon13's Avatar
New User
I have progress springs, drops 2.25 in front and a lil less in back. ingalls front camber kit. the ride is fine. btw, when i had the dc jdm 4 to 1, it was fine even w/ this drop.
Old Nov 29, 2002 | 06:15 AM
95GS-Racin's Avatar
For those of you with H&R OE's , how low did it lower your car?
thanks
