Dash Dimmer switch Dims Climate control, and defrost/foglight switch but not cluster?? Why?
Old Nov 27, 2002 | 06:31 PM
.jacob's Avatar
Default Dash Dimmer switch Dims Climate control, and defrost/foglight switch but not cluster?? Why?
I'm installing my SiR interior components and when I fiddle with the dash dimmer switch and my deforst/foglight switch and climate control both dim but the cluster is completely uneffected. Anyone have any ideas? Trouble shooting? What to look for? Thanks in advance.
-Jake
Old Nov 27, 2002 | 07:06 PM
Civicboy's Avatar
Default Re: Dash Dimmer switch Dims Climate control, and defrost/foglight switch but not cluster?? Why? (Chi
JDM clusters don't dim. mine doesn't either.
Old Nov 27, 2002 | 07:12 PM
SCo77iDAwG's Avatar
i'm not quit certain, but in order to dim your clusters brightness etc. you have to swap something out from your ex/si clusters over to your sir clusters...
.jacob's Avatar
That sucks!!!!!!!! Mine is like sooo faint. Especially on the fuel level meter, its so hard to read at night. Why wouldn't it be able to fade?!? That blows.
-Jake
Old Nov 27, 2002 | 07:15 PM
.jacob's Avatar
What do u have to swap, I need to make my SiR cluster brighter
Old Nov 27, 2002 | 07:18 PM
SCo77iDAwG's Avatar
i've done it before, but i don't remember wat i did. my sir guages on my cpe were bright as hell when i swap some miscellaneous part from ex clusters
Old Nov 27, 2002 | 07:19 PM
.jacob's Avatar
I'm using my USDM plugs in the SiR cluster (the 2 big grey plugs) I can't think of what else could be swapped?
-Jake
Old Nov 27, 2002 | 07:41 PM
Civicboy's Avatar
you might want to check your bulbs to see if you have one out. it shouldn't be that hard to see at night. I can see mine just fine at night.
YEAH!
Oct 3, 2011 07:19 PM
SIDreamer
Feb 9, 2010 08:04 PM
93Civic_hb
Apr 4, 2008 03:50 AM
tonychony
Mar 15, 2008 03:10 PM
Frog
Nov 8, 2002 11:51 AM
