Cracked crank pulley...
Old Nov 27, 2002 | 11:23 AM
liquid51's Avatar
Default Cracked crank pulley...
Anybody know where I can get an OEM crank pulley from a 2000 Euro R Accord H22? Mine cracked to pieces in shipping. I could use a standard h22 dual belt pulley, but I only have alt. so I only need (want) a single belt pulley. And I don't want an after market underdrive 'cause I want the harmonic dampening of the OEM.
Old Nov 27, 2002 | 11:27 AM
Accord94DX's Avatar
Default Re: Cracked crank pulley... (liquid51)
http://www.car-part.com
Old Nov 28, 2002 | 07:45 PM
JPX's Avatar
JPX
Why not Unorthodox Racing Pulley Kit.
My car was the original test Vehicle and has 125k
Running synthetic and +220hp
Still Gangster....
Read Their FAQ on the Pulleys..
Old Nov 29, 2002 | 12:02 AM
XxRONNxX's Avatar
New User
If I were you, I'd try inlinefour.com or jdmhondaparts.com They may be able to get it for you.
Old Nov 29, 2002 | 01:37 AM
KTeller8's Avatar
Default Re: Cracked crank pulley... (AccordSiR)
Old Nov 29, 2002 | 01:09 PM
liquid51's Avatar
Default Re: Cracked crank pulley... (KTeller8)
Unorthodox UD pulleys (as well as almost every other aftermarket) aren't harmonic dampers. I've heard of extremely premature bearing wear and oil pump failure because of accessory vibration. I just don't want to go there. I'm not saying they're bad, I just don't want to take a chance. UNLESS somebody knows how much vibration the alt. causes by itself. I don't have ac or ps. I suppose if the alt isn't too bad I might still consider a prodrive oil pump gear and an unortho UD.
SeraphimKidd
Jun 14, 2009 09:37 PM
airsoft
Aug 6, 2006 04:49 AM
dunkd
Jun 6, 2006 09:49 PM
zracer240
Jan 20, 2006 07:29 AM
