fuel pump underneath the seats
Old Nov 27, 2002 | 10:32 AM
JeremyL's Avatar
Default fuel pump underneath the seats
is this the only pump the car uses? its a 94 LS
Old Nov 27, 2002 | 01:24 PM
Regular Series's Avatar
Default Re: fuel pump underneath the seats (JeremyL)
Yup.
Old Nov 27, 2002 | 05:17 PM
skunkintegra's Avatar
Default Re: fuel pump underneath the seats (risingson77)
is this the same for 97 gsr?
Old Nov 27, 2002 | 05:21 PM
Default Re: fuel pump underneath the seats (skunkintegra)
Should be. I believe all G3s have fuel pump access under the rear seat.
[Modified by risingson77, 9:21 PM 11/27/2002]
Old Nov 27, 2002 | 07:31 PM
cool...i might need to get in there
the gsr has been having problems starting sometimes...it wont start on the first turn of the key..only happens occasionally...REALLY ANNOYING ME...it turns over, just wont start until 2nd maybe 3rd crank
Old Nov 27, 2002 | 10:48 PM
GSRaCeRbOI's Avatar
pretty much all the honda/acuras (civics, integras, etc) I've worked on have had their fuel pump under the rear seat/trunk area where the gas tank is..
Old Nov 27, 2002 | 10:52 PM
piatl7il77's Avatar
Did you check to see if you where getting a spark from the plugs. Could be that too.
Old Nov 28, 2002 | 05:05 AM
Default Re: fuel pump underneath the seats (piatl7il77)
Yes...plus change your fuel filter if you haven't for more than thirty thousand miles. You should do that anyway, because a restricted fuel filter will burn out your pump.
Old Nov 28, 2002 | 07:25 PM
JeremyL's Avatar
i was just doing in preparation for my turbo coming up, woudl the stock fuel filter be enough for say 220whp?
Old Nov 30, 2002 | 09:23 AM
Eh, I wouldn't take the chance. Considering how much less expensive a performance fuel pump, filter and presuure regulator are than a new engine.
Old Nov 30, 2002 | 10:06 AM
SIK IN DA HED's Avatar
New User
do a fuel pressure check. order a b&m fuel pressure guage and check to see if the fuel pressure is low. sign of a bad pump. you can also have a friend help you to check to see if your pump even turns on at power. i looked at my pump the other day and the filter was dirty... but it still turns on and pumps fuel. i found problems with my car mainly through ignition failure.
S_F
Jul 7, 2018 03:23 AM
enriquev
Oct 11, 2007 05:31 PM
chump2825
Feb 23, 2007 01:51 PM
ludecrasy87
12
Jan 8, 2007 05:51 AM
trooper0641
Nov 10, 2004 11:01 AM
