Swapping low-beam to high-beam
Old Nov 27, 2002 | 08:50 AM
mugenracer's Avatar
Default Swapping low-beam to high-beam
I tried the search but cant find anything, i know there was a thread a while back but cant find it. Anywho has anyone changed around their lights so that the low-beams are in the hi-beam housing and vice-versa. If so is there any better light when on low beam from the hi-beam light. I figured there would have to be, but then the hi-beam light would possibly be pretty poor. i havent looked yet to see if the wiring is long enough to stretch across, but was just wondering first has anyone done it in their integra?
Old Nov 27, 2002 | 09:36 AM
IntEGNYC's Avatar
Default Re: Swapping low-beam to high-beam (mugenracer)
I recall a similar thread where you can use the high beam bulbs in the low beam lamps by scraping the **** off the bulb base.
theres also a cap on the low beam bulbs that the high beams bulbs dont have.
try searching on the 9007 or 9005 conversions.. or something like that.. sorry. i just have 2 min between breaks to write this.
good luck
Old Nov 27, 2002 | 11:08 AM
mugenracer's Avatar
Default Re: Swapping low-beam to high-beam (IntEGNYC)
Sorry thats not what i meant, i already done the 9005 conversion on the lo-beams, what i'm considering is changing the complete plug/bulb from the lo-beam into the hi-beam housing and vice-versa, so when i turn on my low beams only, they will shine out of the hi-beam light housing, and the hi-beams will shine from the lo-beam housing
Old Dec 3, 2002 | 10:41 AM
IntEGNYC's Avatar
I think i saw a kit that made daylight running lights for your integra that let the inner light lenses go on. if i find the link, i 'll update thsi post. but i thought it was interesting.
Old Dec 3, 2002 | 01:23 PM
Adriano's Avatar
its simple. just switch the plugs.
Old Dec 3, 2002 | 01:45 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Swapping low-beam to high-beam (brryder)
uhhh you would NOT want to do that. The projector has the cutoff beam pattern that keeps the light on the road and not in other people's eyes. The high beams shine the light way up high, even some straight up and to the sides. Using the high beam housing for your low beams would be
Besides, projectors are superior to reflector headlights anyway.
Old Dec 4, 2002 | 11:01 AM
IntEGNYC's Avatar
Default Re: Swapping low-beam to high-beam (PatrickGSR94)
Agreed be kind to your fellow drivers
Old Dec 4, 2002 | 11:22 AM
thaiphob's Avatar
Nikon!!!
Old Dec 4, 2002 | 02:41 PM
mugenracer's Avatar
Default Re: Swapping low-beam to high-beam (thaiphob)
Ok thats cleared that up, i was just wondering what effect it would have on the lights, but i dont want everyone flashing their lights at me because i'm blinding them!
clkupai
Nov 25, 2012 09:15 AM
byc_cb7
Jun 20, 2009 07:20 AM
mrteggie
Aug 14, 2007 11:06 AM
Fuster_Cluck
Sep 11, 2006 05:49 PM
hYpE-R-29
Dec 29, 2004 04:14 PM
