can i install 6-1/2 coaxials in the doors of a 90 crx si ?
how is the easiest way to put 6-1/2 coaxial speakers in the doors, with it being able to clear the magnet without hitting the back?
they are the blue and silver pioneer model 200 watts each max
and anybody with pictures, that would help tons also, thanks
i did a search, but could'nt find anything on this
Take off the door panels. Remove stock speakers. Remove plastic basket. Cut out the back of the plastic basket. See if the speakers will fit. If not you can use a thin spacer from an Audio shop(Circuit City). If they still don't fit, you can space out the window track. Remove the 10 mm bolt on the bottom front, get a longer bolt and reinstall with washers between the track and door panel.
what is the "plastic basket" ? , just wanting to make sure i cut the right thing, but thanks for the info
just one more thing, if i cut the plastic basket, then i should just be able to bolt up the speaker in the stock location holes? or do i need to drill different holes?
or if the speaker is too deep, is there a way i can just cut a circle through the stock speaker panel on the door, to where the speaker would be visible from the outside with the speaker cover on it?
any info would help thanks
Some speakers will fit in stock screw holes(pioneer) some wont. I usually use 1 1/2 " drywall screws and make my own with a drill/driver. You can ghetto mount it if you want, but I would suggest the other methods.
mlmcgreg
Sep 8, 2007 04:14 AM
Ralph Wiggum
May 17, 2007 03:31 PM
acuraLSSE95
Audio / Security / Video
Jan 1, 2002 08:00 PM
