How much power can you expect from a MiniMe Setup? Less then Z6?
Old Nov 27, 2002 | 06:57 AM
smithbling's Avatar
Default How much power can you expect from a MiniMe Setup? Less then Z6?
I was going to convert the A6 to vtec via mini-me swap. I have heard that the gains are very minimal? Is this true?? I was expecting to get a conside amount more on the highway.
Old Nov 27, 2002 | 07:04 AM
markedOO1's Avatar
Default Re: How much power can you expect from a MiniMe Setup? Less then Z6? (smithbling)
..kinda depends on how you set it up.... if its run with the pm6, it'll be starved for fuel/spark in the upper rpm, so you wont be makin much more power..if ran a fuel controller, that'd change things...or if you ran the p28 ecu, that'd change things...so its really dependent on your electronics... (imo)
Old Nov 27, 2002 | 08:12 AM
smithbling's Avatar
Default Re: How much power can you expect from a MiniMe Setup? Less then Z6? (efzero.com)
I have been told that the SOHC ZC has 112HP. For myself I have found that it is rated at 118HP. I was going on the assumption the motor is 112HP based on my trap speed and comparing to others.
The HP differences between the A6 and Z6 are due to the pistons or head.
It seems like the swap would only cost me about 300US anyway.
However, the car is my winter beater so maybe I should just leave it.
Old Nov 27, 2002 | 10:44 AM
donesixer's Avatar
Give Standard Auto Wreckers a call or http://www.standardautowreckers.com
They are over in Scarborough.
Y8 head $150CDN.
Look into a OBD-OBD1 conversion harness and a P28 computer. US$300 sounded a little steep to me.
Old Nov 27, 2002 | 11:57 AM
smithbling's Avatar
Default Re: How much power can you expect from a MiniMe Setup? Less then Z6? (donesixer)
Nice, yeah I was considering new gaskets/headbolts etc..... vtec controller also.
I am just concerned about not getting the gains. I can pick up a D16Z6 in T.O. for about 250-300CAN, the whole motor!
How hard to convert to OBD-I though?
Old Nov 27, 2002 | 12:08 PM
donesixer's Avatar
Where are you getting that enine so cheap?
The OBD conversion is just a jumper harness. I am making one for my brother's '88 CRX as well. Not terribly hard, just really, really.....really tedious.
Old Jun 12, 2003 | 01:05 PM
Iceycrx's Avatar
If you search around you can do the swap under 100$, if you can't wait I have seen it done up to 500$
88EFsedan2
Jan 22, 2012 07:45 PM
my Efin SI
May 31, 2010 06:05 PM
mario_pic
13
Feb 4, 2008 10:19 PM
D16SiHatch
25
Jul 28, 2007 11:17 PM
EF9 JAMS!!!
Dec 29, 2005 08:13 PM
