I'm Getting a code 8...what does it mean?
Old Nov 27, 2002 | 06:18 AM
honda_joe's Avatar
Default I'm Getting a code 8...what does it mean?
After we replaced the distributor on my 93 Accord LX, I am getting a real low idle and it cranks a lot before it fires. Yesterday, the engine light came on. I did the paperclip trick and it flashes 8 times, all short. This means a code eight. Am I correct? I researched and it seems a code 8 means a "Top Dead Center Sensor" error. What exactly does this mean and how do I fix it? Could it be that my timing is off?
Thanks
Old Nov 27, 2002 | 08:39 AM
Stew Pidasso's Avatar
Default Re: I'm Getting a code 8...what does it mean? (honda_joe)
Your Top Dead Center Sensor is bad or you unplugged it while changing your dist..
[Modified by Stew Pidasso, 12:41 PM 11/27/2002]
Old Nov 27, 2002 | 12:55 PM
bill-71SS's Avatar
on your car the sensor is in the dist. It is either bad, or the wiring ir on wrong. chances are with a aftermarket dist.,you got a bad one.
killafred187
Aug 12, 2011 05:15 PM
crusto2k3
Dec 1, 2008 02:14 PM
hondacrx2
May 9, 2007 10:43 AM
ham
Mar 7, 2007 08:26 AM
SpoolinEK
Jun 16, 2002 11:23 PM
