Who heres an electrical genious? If so can you please help?
take a look at this please: https://honda-tech.com/zerothread?id=344685
if you ask me it sounds like your battery is SHOT and needs to be replaced, i remember once when i killed my battery the car would barley start even w/ jumper cables, drove like **** and on the way to walmart to get a new one, everything stopped working like the guage cluster, lights etc. replced the battery and all was good..
The symptoms you described sounds like you have a weak battery. Especially the change in temperature affecting it. Change the battery.
The above posts are correct however, if I were you I would go to Pep Boys or Autozone whatever and have them test the battery and alternator for free. This will verify the problem at no cost to you. Then if you still have problems it's most likely a bad ground.
JUN.
Jan 25, 2010 07:55 AM
imnotswapped
Feb 17, 2004 10:03 AM
