springs or coilovers?
Old Nov 26, 2002 | 08:43 PM
IntegrasGoFast's Avatar
Default springs or coilovers?
why are coilovers so much more expensive than springs? whats the big advantage?
for daily driving which is best?
Old Nov 26, 2002 | 08:48 PM
Understeer's Avatar
Default Re: springs or coilovers? (IntegrasGoFast)
Coilovers are height adjustable, have higher spring rates, corner weighting and the dampers are designed to work with the high spring rates.
Springs are cheaper because they are non adjustable.
Daily driver I would get a nice set of spring (H&R, Eibach, Neuspeed, Spoon)
If you plan on racing go with the Coilovers.
Old Nov 26, 2002 | 09:20 PM
slimbo's Avatar
Default Re: springs or coilovers? (Understeer)
coil overs aren't necessarily better. basically you are paying for the height adjustability.
Old Nov 26, 2002 | 09:44 PM
SIK IN DA HED's Avatar
New User
Default Re: springs or coilovers? (slimbo)
adjustability = convenience
Old Nov 26, 2002 | 09:45 PM
threatcon13's Avatar
New User
Default Re: springs or coilovers? (dlplayboy)
depends on the drivers needs
slimbo's Avatar
well.... only if you need to change the height.
think about it. every time you change it you are meant to get a wheel alignment and get the corners weighed....
Old Nov 26, 2002 | 11:46 PM
frogsr's Avatar
why are coilovers so much more expensive than springs? whats the big advantage? for daily driving which is best?
for daily driving stock springs are best. your question is too vague. the biggest advantage for having coilovers over standard springs is the ability to adjust the height and cornerweigh/balance your car.
Old Nov 27, 2002 | 01:58 AM
hitop's Avatar
Default Re: springs or coilovers? (frogsr)
Just keep it simple for now and go with a set of good springs and dampers.
Old Nov 27, 2002 | 04:10 AM
Ricky Rojales's Avatar
Default Re: springs or coilovers? (hitop)
Old Nov 27, 2002 | 05:02 AM
LYKBUTTA's Avatar
Springs!!!!!
Old Nov 27, 2002 | 05:47 AM
metal-x's Avatar
Default Re: springs or coilovers? (LYKBUTTA)
coilovers
Old Nov 27, 2002 | 06:34 AM
Ferrell's Avatar
wrong.
stop giving false information.
Old Nov 27, 2002 | 07:06 AM
Acronym's Avatar
Yeah i would so rather be able to adjust definitely 4 weather conditions around where i live! Soon we are expecting snow so my car is kinda high not stock height but about inch lower! Trying to get over the snow not plow the ****!
halloween_ninja
Jan 19, 2009 08:01 PM
JDM ej1
Apr 21, 2004 05:03 AM
Adam.
Sep 15, 2002 03:14 PM
yotaplay
Sep 8, 2002 06:13 PM
preludeChaos
Oct 9, 2001 07:28 AM
