Preparing to do swap (please fill me in)!!!
Old Nov 26, 2002 | 08:02 PM
fcuked's Avatar
Default Preparing to do swap (please fill me in)!!!
I have been around 3 swaps, i've just done mechanical labour it was a while ago so i can't really remember what I was doing. I mean i can do it, but i will just end up learning everything the hard way...might as well try and save my trouble as i am doing this swap on my own
Putting a 99 Civic DX OBD2 motor in a 92 civic hatch and pulling out a LS motor of it first.
Can you list all the tools i will need, i know there are some out of the ordinary sizes, i believe one was 32mm socket??? All the little things like that...i'd appreciate it...
Any little tips/tricks will be appreciate. Also if you guys know any websites that would be of help too. Thanks.
[Modified by 1.8 HB, 5:03 AM 11/27/2002]
Old Nov 26, 2002 | 08:05 PM
JaeOne3345's Avatar
Default Re: Preparing to do swap (please fill me in)!!! (1.8 HB)
http://www.c-speedracing.com/howto/b18cswap/swap.html
[Modified by JaeOne3345, 9:05 PM 11/26/2002]
Old Nov 26, 2002 | 08:15 PM
97hb's Avatar
You need a couple of long sockets like 17mm and 14mm. Also a set of punches for the shift linkage bitch pin. An impact wrench comes in handy(not needed though). A good breaker bar. Rent the ball joint puller for $20 at autozone and when you return it, you get your money back minus taxes. Cherry picker, jack, jack stands, and something to drain all fluids into.
Old Nov 26, 2002 | 08:19 PM
fcuked's Avatar
Default Re: Preparing to do swap (97hb)
Thanks a lot guys.
eagarcia88
Honda Civic (2001 - 2005)
Apr 28, 2011 04:20 PM
Rafal
Mar 11, 2007 04:51 AM
1slowcrx
Welding / Fabrication
28
Nov 29, 2005 05:10 PM
PuzzelingRG
Nov 9, 2005 02:32 PM
HybridHatchC1
Nov 27, 2002 02:19 PM
