Torque Spec please: Um B pillar chassis brace?
Old Nov 26, 2002 | 06:48 PM
sackdz's Avatar
Default Torque Spec please: Um B pillar chassis brace?
I don't know what it's called... but it's not in my service manual. The 3 pcs of black painted steel on the floor right where the rear seats would fit. Several large bolts hold them down. Well I need to take that off to remove my seatbelts it appears.
Does anyone have the torque specs for it? Is this a Type R specific part?
Old Nov 26, 2002 | 06:51 PM
Reid's Avatar
Global Moderator
Default Re: Torque Spec please: Um B pillar chassis brace? (sackdz)
Really?
I've never removed that piece on any of the cars that I've removed the rear seatbelts from.
Old Nov 26, 2002 | 06:52 PM
Dave-ROR's Avatar
no you don't sackdeeznutz.
Old Nov 26, 2002 | 07:02 PM
sackdz's Avatar
Default Re: Torque Spec please: Um B pillar chassis brace? (Dave-ROR)
Well how am I supposed to get the retractor bolt out if theres ****** 1/2" steel covering it?
Is this an 'ITR' piece?
Old Nov 26, 2002 | 07:03 PM
IN VTEC's Avatar
I think it is a R specific cross brace.
16lb*ft for all the horizontal bolts and those not directly under the rear seat. These are the shorter bolts (8mm)
28 lb&ft for the ones directly underneath the seat. Th'are da lunger ones (10mm).
[Modified by IN VTEC, 10:05 PM 11/26/2002]
Old Nov 26, 2002 | 07:04 PM
sackdz's Avatar
Default Re: Torque Spec please: Um B pillar chassis brace? (IN VTEC)
Well then I seem to have misplaced my R supp. somebody want to look up the torque?
Old Nov 26, 2002 | 07:10 PM
sackdz's Avatar
It's not really "B-Pillar" huh?
Dave-ROR's Avatar
Last time I looked at an arrrrrrrrrrrrrrrrrrrrrr I don't recall it being in the way. I will look friday though even though you'll have an answer by then.
Old Nov 26, 2002 | 07:29 PM
IN VTEC's Avatar
Supplement says you need to remove it to access the lower seat belt bolt. It's not always right on the money tho. Might be one of those cases where nonconventional methods are just as effective.
Old Nov 26, 2002 | 07:30 PM
sackdz's Avatar
<I TOLD YOU GUYS SO>
Does it list a torque spec for the brace bolts?
[e]thx in vtec
[Modified by sackdz, 11:30 PM 11/26/2002]
Old Nov 26, 2002 | 07:31 PM
Art Vandeleigh's Avatar
are you talking about removing the rear seat belt buckles?? or the rear seat belt retractor?? if it is for the rear seat belt retractor, which im thinking thast what your talkign about, you DO NOT have to remove anything except, rear trim panel, rear seat, and side trim panel HTH
Old Nov 26, 2002 | 07:38 PM
sackdz's Avatar
Default Re: Torque Spec please: Um B pillar chassis brace? (Art Vandeleigh)
Nope front seatbelt.
Old Nov 26, 2002 | 07:42 PM
[Modified by Art Vandeleigh, 4:45 AM 11/27/2002]
Old Nov 26, 2002 | 07:44 PM
if it is for the fron then you are right here you go:
there are 2 different types of bolts with 2 different tq specs:
the first 3 on top of the bar: 28 lbft / 38 Nm
all the rest (5 total): 16 lbft / 22 Nm
HTH
art - wishes he had a scanner
Old Nov 26, 2002 | 07:55 PM
sackdz's Avatar
No scanner needed muchas gracias.
Old Nov 26, 2002 | 08:12 PM
Dave-ROR's Avatar
why didn't you specify? This whole freakin time I thought you were talking about rear belts
Old Nov 26, 2002 | 08:13 PM
Reid's Avatar
Global Moderator
Old Nov 27, 2002 | 02:30 AM
sackdz's Avatar
Well seeing how theres no "huge pieces of steel" to take off near the rear belts, and the fact I said 'B pillar', I thought it was pretty clear.
Wut the hell do you know, you don't own an arrr anyway...
hehe
Old Nov 27, 2002 | 04:40 AM
Ausmith's Avatar
Sack - its the side impact beam. Just torque it down to 40 ft lbs.
b18bfreak
Nov 28, 2011 06:00 PM
teamm_AP1
Oct 3, 2009 09:25 PM
ntensehonda
Honda S2000
Jan 7, 2009 11:56 AM
NZDelsoldude
Dec 23, 2006 02:50 PM
