Anyone upgrade the M/C and brake booster on an EG ?
Old Nov 26, 2002 | 05:59 PM
chameleon's Avatar
Default Anyone upgrade the M/C and brake booster on an EG ?
did a bit of searching and turned up nothing, need some help on my specific question.. anyone with an EG upgrade the master cylinder, booster or proportioning valve?
my situation is that i just upgraded to ITR 5 lug and I know the CX M/C does a fine job of braking but the brakes have so much more potential, ive heard terms as 4040 adn 15/16 but not sure where these #'s fit in, and what i can do? I want to get the ITR master cylinder and booster, but seems im gonna have to do something about the lines, i see the ITR has 1 in the front and one on the side, would i have to get the prop valve from an ITR as well ? anyone who has messed with this i really need some light !! what you guys recommend is good for me?
Old Nov 26, 2002 | 06:08 PM
JSJ EG6's Avatar
Default Re: Anyone upgrade the M/C and brake booster on an EG ? (chameleon)
use a integra rs proportion vavle cuz the rs got 6 lines.if u use a itr gsr master cylinder you have to bend a line but with a rs it bolts rite on. but the itr/gsr master cylinder is 1 and i think rs is 15/16???dunno if that matters?o yea you cant use a itr/gsr proportion vavle cuz it have 4 lines.
Old Nov 26, 2002 | 06:18 PM
chameleon's Avatar
Default Re: Anyone upgrade the M/C and brake booster on an EG ? (TEAM JSJ)
ok now im getting more information .. here's whats in my head.
1- how hard is it do disconnect the prop valve? its a lot of lines and that thing in on the firewall so im just picturing getting to it and replacing it..
2- why does the rs have 6 lines and itr 4 ? the more lines the better? what are the extra 2 lines for and why shouldnt the itr have that ?
3- the itr is 1in in what ? where does that size come in ? and what will make that different to the 15/16 ?
4- how many lines does the CX prop valve have ?
Old Nov 26, 2002 | 06:22 PM
deftones0817's Avatar
Do this get a integra 1' mc pv and brake booster from sohfast.com
all you will have to do is flair one line...i was clueless and i got it to work...great mod for car.
DEF
Old Nov 26, 2002 | 06:29 PM
chameleon's Avatar
Default Re: Anyone upgrade the M/C and brake booster on an EG ? (deftones0817)
DEF
ok so if i get the itr pv then flare 1 line, then whats up with the extra 6th line?
Old Nov 26, 2002 | 06:34 PM
piscorpio's Avatar
I was actually wondering this myself. I have a VX, and an Si (2000) prop. valve, and the two do not look anything alike. (VX has a dual prop. valve?)
Is it possible to make the Si/Integra valve work with this?
Old Nov 26, 2002 | 06:35 PM
piscorpio's Avatar
Default Re: Anyone upgrade the M/C and brake booster on an EG ? (piscorpio)
Also, I know that 96+ Civic EX's and Si's all have 15/16" MC, and I believe the 94+ Integras all do as well. (except Type R, not sure)
[Modified by piscorpio, 9:35 PM 11/26/2002]
Old Nov 26, 2002 | 06:37 PM
chameleon's Avatar
still confused
neof69's Avatar
Just buy a 92-95 Si Porportioning valve for your cx. NO FLARING required. I also have a 1in ITR MC/BOoster in my EG. NO FLARING required, just some careful rebending.
Old Nov 26, 2002 | 06:50 PM
rob d's Avatar
You need to have a 6 line prop. valve. Unless you have ABS. ABS uses 4 lines. If you can find a Integra RS MC and booster, you wont have to flare any lines or bend any lines.
Old Nov 26, 2002 | 06:51 PM
chameleon's Avatar
Default Re: Anyone upgrade the M/C and brake booster on an EG ? (neof69)
hmmm now when you say get a si pv does that mean the pv and all the lines? how much will hondaparts charge for this? and if it comes with all the lines that means it has 4 ? just like the itr ? how many do i have now on my CX ?
Old Nov 26, 2002 | 06:53 PM
chameleon's Avatar
Default Re: Anyone upgrade the M/C and brake booster on an EG ? (rob d)
so your saying the RS comes with rear disc.. and the mc and booster are 1" so its exactly equivalent to an itr ? just that all my current lines will line up? how hard is it to find the rs mc and booster?
Old Nov 26, 2002 | 06:57 PM
rob d's Avatar
The RS MC is 15/16". 1/16 doesn't make that much of a different. I do have an extra RS MC/booster and 4040 prop. valve just lying around. I just pulled it from a Integra a few days ago.
Old Nov 26, 2002 | 06:58 PM
neof69's Avatar
a porportioning valve at most 60.00 from honda.
Old Nov 26, 2002 | 07:00 PM
shawnhayes's Avatar
Yes.
No. The RS master cylinder is 15/16", but the decrease in cylinder size will give you MORE braking power than the 1" with some compromise in pedal travel.
Trivial. Nobody wants them (except US, of course). You should be able to locate a 4040 proportioning valve and a RS MC and booster from just about any junkyard that carries Hondas at all.
The ITR master cylinder isn't worth the trouble of learning to double flare brake lines. Trust me. Been there, done that. Won't do it again.
Shawn
Old Nov 26, 2002 | 07:07 PM
chameleon's Avatar
Default Re: Anyone upgrade the M/C and brake booster on an EG ? (shawnhayes)
what is the compromise in pedal travel ? like example in the difference..
also what makes a 4040 valve special ? and other are there?
if the 15/16 is the RS, i guess thats the biggest before the ITR 1" , but what is the size of the LS one ? acura has different sizes in all trims ? oh and what size do i have now in a CX ? so i know the gap im upgrading to ?
Old Nov 26, 2002 | 07:14 PM
shawnhayes's Avatar
Like 1/2 of an inch in total brake pedal travel at the bottom (if my estimations are right).
It's designed to properly proportion brake pressure between front Integra/Civic disc brakes and rear Integra/Civic disc brakes.
There are 3030's, 4030's, and 4040's. I cannot tell you what every one is for (and I'm too lazy to go down and look at my old one), but the 4040 is for Honda Integra/Civic 92-2001 front disc and rear disc setups.
I have no idea what the LS one is (don't have a manual for that one, sorry). The CX is 13/16" - so now you know.
Shawn
Old Nov 26, 2002 | 07:18 PM
rob d's Avatar
I think all civic and integra with r. disks use 15/16 MC.
Old Nov 26, 2002 | 07:20 PM
shawnhayes's Avatar
Except for some of the ABS systems have th 1" MC, and the ITR has a 1" MC.
Shawn
Old Nov 26, 2002 | 07:24 PM
chameleon's Avatar
dont some JDM ITR's have no ABS, i guess for track use,...errr... so getting a jdm itr 1" mc w/o abs would be good?
Old Nov 26, 2002 | 07:44 PM
chameleon's Avatar
this is the info i have so far.
1- i have 6 lines, but no 4040 pv, but a non abs pv from an rs is 6 line and 4040
2- rs mc and booster are 15/16 and have no abs so no modding needed.
3- itr is 1" same for gsr but they have abs so flaring and bending needed.
4- 96-97 itr has 1" mc and booster and no abs
Old Nov 26, 2002 | 09:38 PM
chameleon's Avatar
ttt
Old Nov 26, 2002 | 09:45 PM
nijia555's Avatar
i have abs on my sh*tbox does this mean that my mc is 1" ?
Old Nov 26, 2002 | 09:54 PM
chameleon's Avatar
Default Re: Anyone upgrade the M/C and brake booster on an EG ? (nijia555)
no.. only gsr's and ITRs have 1" mc
Old Nov 28, 2002 | 04:21 AM
S&P500ITR's Avatar
New User
I took pics of my setup, whick I believe is #2 on your list. The MC is a 15/16
compared to stock
[Modified by S&P500ITR, 6:23 AM 11/28/2002]
