Should I buy a Toda Header or go with a ATS + Toda flywheel.
Old Nov 26, 2002 | 08:37 AM
ck01R's Avatar
Default Should I buy a Toda Header or go with a ATS + Toda flywheel.
I know there is a little difference in the price between the header and ATS/Flywheel comarison....however, what would you all do if you were in the same spot contemplating what to do? I know I should go with what I think is best...however, I was just wondering what your thoughts were....thanks
Old Nov 26, 2002 | 08:44 AM
sgT's Avatar
sgT
Default Re: Should I buy a Toda Header or go with a ATS + Toda flywheel. (ck01R)
Honda 4.785 FD + Fidanza flywheel.
Old Nov 26, 2002 | 08:55 AM
ck01R's Avatar
Default Re: Should I buy a Toda Header or go with a ATS + Toda flywheel. (sgT)
I heard the JDM version of the final drive isn't as great as the ATS 4.9.... I am just asking what you all would do...thanks for the reply!
Old Nov 26, 2002 | 09:54 AM
ck01R's Avatar
Old Nov 26, 2002 | 09:57 AM
hungsteR's Avatar
What application are you going to mainly use the car for?
Old Nov 26, 2002 | 09:59 AM
Back in Black's Avatar
Rather OG
I have done all three. (Toda header/flywheel, ATS)
If I started from scratch again, I would do the flywheel and final before anything.
ITRinEJ1's Avatar
depends on what you want to use this for.
JDM FD is a lil more streetable and still helps out in the acceleration dept. for the more weekend/track warrior ATS works out better cuz it is much more aggressive!! not meaning that ATS is not streetable, just that it will take a lil getting used but; but i know once u do it is hella fun
but either way u cant go wrong.
Old Nov 26, 2002 | 10:00 AM
ITR764's Avatar
Default Re: Should I buy a Toda Header or go with a ATS + Toda flywheel. (hungsteR)
ATS/Toda FW
then go buy a JDM 4-1 header...
Old Nov 26, 2002 | 10:12 AM
JDMITR222's Avatar
Default Re: Should I buy a Toda Header or go with a ATS + Toda flywheel. (ITRinEJ1)
Old Nov 26, 2002 | 10:14 AM
Hooch'n's Avatar
Default Re: Should I buy a Toda Header or go with a ATS + Toda flywheel. (JDMITR222)
I'd say header!
Old Nov 26, 2002 | 10:15 AM
Austin's Avatar
Agreed...and with the amount that you save you can almost buy the header that you're looking at...
Old Nov 26, 2002 | 10:18 AM
Warren's Avatar
Wrong-Way Wang
ATS is too short for road courses.
Warren
Old Nov 26, 2002 | 10:48 AM
ITR-01-0977's Avatar
New User
Default Re: Should I buy a Toda Header or go with a ATS + Toda flywheel. (Warren)
ats and toda flywheel
Smitdog's Avatar
Default Re: Should I buy a Toda Header or go with a ATS + Toda flywheel. (ITR-01-0977)
Old Nov 26, 2002 | 10:59 AM
sgT's Avatar
sgT
Default Re: Should I buy a Toda Header or go with a ATS + Toda flywheel. (Smitdog)
man, you all love the HEAVY flywheels....
Old Nov 26, 2002 | 11:07 AM
TodaSi's Avatar
sgT - - The thrifty shopper
Old Nov 26, 2002 | 11:11 AM
Reid's Avatar
Global Moderator
Default Re: Should I buy a Toda Header or go with a ATS + Toda flywheel. (TodaSi)
Comptech 6.75 lb flywheel
Old Nov 26, 2002 | 11:12 AM
B2FiNiTY's Avatar
Old Nov 26, 2002 | 11:48 AM
Black R's Avatar
25 Year Member
ats, competch flywheel, AND toda header.
Old Nov 26, 2002 | 11:59 AM
Willard's Avatar
weight is not the whole story.
where 'it' is located is what matters.
Old Nov 26, 2002 | 12:09 PM
sgT's Avatar
sgT
Default Re: Should I buy a Toda Header or go with a ATS + Toda flywheel. (Willard)
this is true. and in that respect the fidanza should still be lighter.
Old Nov 26, 2002 | 12:20 PM
ITRinEJ1's Avatar
Warren
not from the one i rode in with it at gingerbitch
but if u want to get technical, gearset maybe more better suited first than a FD!! just an opinion
ck01R's Avatar
thanks for all the replies guys...I have heard that the Toda was the best flywheel...but maybe not? Also, it sounds like the ATS isn't that streetable...nor good for road courses? why is this?
Thanks again for the replies and keep them coming!
Old Nov 26, 2002 | 12:21 PM
Warren's Avatar
Wrong-Way Wang
On any sizable straight you will tap out the ATS on the stock rev limiter.
Warren
Old Nov 26, 2002 | 12:24 PM
ITRinEJ1's Avatar
by all means dont take it as me saying the ATS is not streetable, it is very much streetable!! its just that you will have to put up with minor annonyances like cruising at higher RPMs, etc. which alot of us dont really care anyways!!
