rear discs on a 91'civic hb
Old Nov 26, 2002 | 03:35 AM
hornetd23's Avatar
Default rear discs on a 91'civic hb
Are there any rear disc conversion kits for my 91'civic hb or can I just get discs off some other honda/acura that will fit?
Old Nov 26, 2002 | 04:31 AM
spun Vtec's Avatar
Default Re: rear discs on a 91'civic hb (hornetd23)
use search
Old Nov 26, 2002 | 04:49 AM
SuperCivic's Avatar
hey there buddy, there's a plethora of info on this subject if you search.
you can use the rear discs (entire trailing arms) from the crx si, a 90-93 integra, or a jdm Si or SiR. don't forget to get the ebrake cables, master cylinder and booster, and proportioning valve.
Old Nov 26, 2002 | 08:10 AM
andrew dc's Avatar
Default Re: rear discs on a 91'civic hb (SuperCivic)
if you are going to install in a hatch.. use the 90-93 teg stuff... since the ebrake cables will be the perfect length
Old Nov 26, 2002 | 09:52 AM
my_slow_civic's Avatar
Default Re: rear discs on a 91'civic hb (CRX25)
I have a full setup for sale if interested.
Old Nov 26, 2002 | 10:18 AM
REDBARON's Avatar
Default Re: rear discs on a 91'civic hb (sirk)
FYI.
Also, you don't neccesarily need the MC, brake booster, and proportioning valve when doing the swap. But it is recommended to take advange of the rear disks.
For your car you're going to need the complete trailing arm from either a 90-91 CRX Si, or 90-93 Teg. But only the 90-93 Coupe Teg E-brake cables will work for the HB. Just swap it out, bleed the brakes and you're done. You can install the MC, BB, and PV from either car to fully complete the rear disk swap. But it's not required.
crxturbo585
Jan 12, 2008 07:35 PM
gutted-dx
Jul 28, 2004 09:55 AM
buckNasty
Jan 7, 2004 08:45 AM
Pissoff
Jul 20, 2002 04:01 PM
maximedx
11
Mar 14, 2002 04:58 PM
