Direct Bolt In Engines?
yes
any D series engine will bol tinto ur chassis except the A1 off the 87 teg... need mounts... but using stock mounts u can use the 88-00 D series..
dont b16a engines bolt directly onto 92-00 civic chassis as well? i heard that was true, but you need engine mounts to bolt in a b series into a crx. so...my question is, if a b series bolts straight into d series mounting, but the crx will not accept a b series without new engine mounts(or fabricated), how does a d series from the civics(z6, y8) bolt into a crx? confusing? sorry. dont no how else to put it
