Anyone removed the key and used push buttom start ?
Or does anyone have a wiring diagram for the 89 CRX si ?
I'm not sure what wires go where and I cant find anything in my chiltons manual!
Thanks
!~Jonathan
Thanks
!~Jonathan
For starters-buy the Helm. The complete wiring diagram is in there. You can actually remove the switch from the column as it bolt on the back of the lock cylinder. The other option is to buy a new switch assembly because it has all of the wires on it.
I can tell you that the switch has several feeds on it including one for the starter relay and MAIN relay. It might be possible that a delaer would let you copy the drawing in the shop manual.
I know when I was making my cigarette lighter a push button start I new what was for what but thatwasout 5 months ago. All I know now is that the white w/ pink stripe is ACC. and black is the one that goes to the starter. But I didn't remove my key, its still fully fuctional execpt for the Start position. Turn key to run and push cigarette lighter and go.
Give me a while and I'll try to find out the rest.
winnerpl
Audio / Security / Video
May 13, 2006 07:07 AM
