help
I just put a 91 crx si engine in my 90 std hatch and I have everything hooked up correct, I have fuel at the plugs and also a spark but the car will not start, it turns over but will not start up it acts like it want to once in a while but it will not any suggestions
[Modified by civteg1, 11:23 PM 11/25/2002]
did you replace the timing belt? yeah, that could be possible. check all you ground wires. make sure the cams markings line up level w/ the head at tdc. check fuses too.
b16_r3x
Jan 31, 2011 06:46 PM
indy_parrothead
May 5, 2003 11:15 AM
