2nd get guage cluster
really shouldn't be that hard. the easiest thing to do is to find the wiring diagrams for your car, and one for the teg..haynes manuals have this info..also a few other sites might help, use your search of the archieves to find them.
another way of doing this is to take the cluster and make your own chart. look at the wires, write down their order and color. if you look at the back of the cluster there is a printed circuit board on the back. this can tell you what most of the pins do..you trace around the map to which ever sensor it ends at..for example, you trace a pin out that ends at the oil light..viola, it's the check oil light. black are always ground, and yellow is usually switched power to cluster. i used this method when i got confused with the SiR cluster..it works. good luck mang
