boiling dot 4 brake fluid
anyone ever have a problem with it? i was only driving hard for about 30 minutes and when i checked the fluid level the next day it was right at the minimum level. it was still at the max level when i checked the level last weekend.
...you would have to be doing some seriously hard driving to boil that much fluid...
what do you use that dot 4 anyways? I thought the brakes use only dot 3?
your NOT boiling it, your just useing up your pad, when you do that, the fluid gets pushed from your MC to your calipers, so your fluid level gets lower in the MC.. Check your pads out..
