need help with strange "miss", second gear
Old Nov 24, 2002 | 10:33 PM
DJ:A's Avatar
New User
Default need help with strange "miss", second gear
howdy
i've been having a problem for a while now....at certain times, on the same roads and same corners, I will experience a "miss" of sorts in 2nd gear, at normal cruising speeds. Basically, there is a hill i always come down, 3rd gear, then shift in to 2nd to turn left onto another little incline. quite often, at this point the car will kind of bog down to a low rpm, and i wont modulate the throttle at all. it jumps revs down and up two or three times then rights itself. It never does it just going through stop lights, just around the same roads all the time. Could it be an issue with the spark? any help is appreciated.
DJA
PsychoSiRex
Honda Civic (2006 - 2015)
Sep 16, 2009 09:15 PM
ekcoupe88
16
Apr 26, 2007 09:05 AM
fullcollapse0085
May 2, 2003 10:58 PM
vicz
Apr 17, 2003 06:38 AM
