Will shift linkage from a 99 b16 si work in a 92 cx h/b
Old Nov 24, 2002 | 07:23 PM
slcxow's Avatar
Default Will shift linkage from a 99 b16 si work in a 92 cx h/b
Will shift linkage from a 99 b16 si work in a 92 cx h/b? Also, will a p28 ecu work with the motor as a plug and play??
Old Nov 24, 2002 | 07:44 PM
chet's Avatar
Default Re: Will shift linkage from a 99 b16 si work in a 92 cx h/b (slcxow)
shift linkage will work (its the cheapest shift linkage sold by honda)
a p28 will plug in, but the fuel curves and rev limiter will be different from the stock cx motor...although i guess you're putting a b-series motor in, and if this is the case you'll need to get that chipped, and i'd suggest a vtec controller and tuning as well.
chipped p28's with skunk program run rich as hell, which will lead to ring failure if you drive like that for a long period of time.
Old Nov 24, 2002 | 08:19 PM
salbaje's Avatar
yes they will work
Old Nov 25, 2002 | 05:19 AM
slcxow's Avatar
Default Re: Will shift linkage from a 99 b16 si work in a 92 cx h/b (chet)
Yes its a b series going into the 92 cx. Do you have to get it chipped? b/c the swap is going to be done this weekend. Also, what else you guys recommend doing to make this swap easier. I have the everything except 2 mounts and the downpipe. Please reply with any suggestions. thanks again
Old Nov 25, 2002 | 09:28 AM
Kataku2K3's Avatar
I normally change the clutch, t-belt, water pump, distributor cap and rotor, and plugs... Good Luck
97dssi
Oct 20, 2010 03:23 PM
SL0-hatch
Dec 14, 2006 09:20 AM
eg_hatch_si
Jan 7, 2005 04:58 AM
Desperado
May 23, 2003 08:00 PM
