Cluster Cover Help??
Old Nov 23, 2002 | 10:57 PM
B20zvtecek's Avatar
Default Cluster Cover Help??
Ok i got an 89 Si , You know how the emergeny switch is on the column cover?
I want to use a 91 CRX cover ,will the emergency button work???
Is only solder required????
oh yeah same for rear defrost too
Thanks Alot
Old Nov 25, 2002 | 03:01 PM
mr. carpenter's Avatar
Default Re: Cluster Cover Help?? (B20zvtecek)
the clusters mount the same but the 88-89 cluster is smaller than the 90-91 so you will be left w/ a gap if you put a 90-91 cover on an 88-89 cluster. i don't think you can put a 88-89 cover on a 90-91 cluster. i'm not sure but i do know the gap is created because i put an 89 cluster in a 91.
Vagitarian
Sep 21, 2012 10:00 PM
DCRB
Aug 12, 2009 07:45 PM
turbo sol
Oct 29, 2004 10:08 AM
kevinm1981
Feb 8, 2004 10:49 PM
