Clutch Help?
Hey guys,
Today I went to start up my 92 VX and the clutch had a completely different feel than it did when i shut it off last night. Now it seems the clutch has absolutely no feel, or rebound, until it almosts hits the floor. It had normal feel when i shut it off last night. What could have happened? I need this tranny and clutch to last through winter, because I will be swapping a b-series in. Can anyone give me any help here. The clutch just doesnt spring back like it should; almost as if the peddle is mushy. HELP>
it could be a couple things.. couple easy things to try is to try bleeding the clutch line. also pop the boot of where the clutch fork is, and make sure that it isn't visibly broke/bent and that the clutch slave cylinder is ok.
Excellent advise.. bleed the clutch and refill it.. it should tighten back up.. one person poors while the other pumps the clutch.. Good luck!
DX187VTEC
Nov 12, 2002 06:41 PM
