Replacing Fuel Pump
Old Nov 23, 2002 | 07:06 PM
tilt's Avatar
Default Replacing Fuel Pump
I'm gonna be replacing the fuel pump on a 91 crx dx. I know the tank has to be dropped to access the fuel pump. It looks pretty straight forward from the diagams I've looked at, but there are a few things I need cleared up.
1. Do I need anything else besides the fuel pump and fuel strainer/filter? any gaskets?
2. I'm looking at pumps available at autozone and advanceautoparts, can you recommend any particular brand from experience?
3. Have any of you worked on the pump without draining the tank, or is it a bad idea?
4. Are there any sites with a how-to? I've looked but no success.
Thanks
Old Nov 23, 2002 | 07:12 PM
USDM 4G VTEC's Avatar
Default Re: Replacing Fuel Pump (tilt)
u can take it from underneith the back seat but thingy..
just remove the rear seat thing.... its acccesible from there...
Old Nov 23, 2002 | 07:53 PM
spettinger's Avatar
Default Re: Replacing Fuel Pump (JDM EF9)
from the top of the rear cargo area is just the fuel level sender, you definitely have to drop the tank. just unbolt the straps that hold the tank up and let it hinge down, the fuel pump is on the driver's rear side. i would go with at least an SI pump, if not something a tad bigger such as a holley or jackson racing pump. i believe the stock out put is somewhere around 95 liters per hour (correct me if i am wrong!) and most of the time i see people upgrading to 155's, or 195's.
Old Nov 24, 2002 | 05:08 PM
tilt's Avatar
Default Re: Replacing Fuel Pump (wreckedhatch)
Thanks. I got the fuel pump installed and working
Old Nov 24, 2002 | 05:28 PM
2camsaam's Avatar
cool
Old Nov 24, 2002 | 05:31 PM
Toptul_Honda's Avatar
New User
Default Re: Replacing Fuel Pump (2camsaam)
so did u have to drop the tank? any noticeable difference?
Old Nov 28, 2002 | 06:37 PM
tilt's Avatar
Default Re: Replacing Fuel Pump (G2-Rex)
yep, had to drop the tank. The lowering/lifting with a jack helped a lot. The new fuel pump is kinda loud tho
Old Nov 28, 2002 | 10:12 PM
Malgerus's Avatar
You'll like it after a while
Old Nov 28, 2002 | 11:13 PM
mannyman's Avatar
El Veterano de Sur Califas
which one did u get after all???
Old Nov 30, 2002 | 04:03 PM
tilt's Avatar
Default Re: Replacing Fuel Pump (mannyman)
i got it from autozone... the brand is Master.
Old Nov 30, 2002 | 06:24 PM
mannyman's Avatar
just wondering...did u replace it because your dx pump didnt work anymore?
Old Nov 30, 2002 | 08:36 PM
tilt's Avatar
Right. The pump was shot but i wasnt 100% sure... the main relay wiring was messed up too. So I didnt want to order an upgraded pump and have it end up not fixing the problem. Plus it's my friend's car... it's been sitting outside for over a year and he let me mess with it to try get it working. After fixing the head gasket, timing belt (reason it was sitting doing nothing), water pump, main relay wire harness, and fuel pump, I have it up and running. It will be mine soon though . It's amazing how many things break when it's just sitting there baking in the sun.
jdmtp7
Jan 7, 2009 09:08 AM
EKSedAndy
Nov 12, 2007 10:22 AM
EK_B
Feb 22, 2007 11:13 AM
dahoopdahup
Jul 10, 2006 08:44 PM
1990 CRX Si
Jan 9, 2006 05:08 AM
