havin problem with JDM ECU
Old Nov 23, 2002 | 04:44 PM
DJHan's Avatar
Default havin problem with JDM ECU
I installed JDM P73-013 yesterday and let it learn for 15+mins
and went for test drive , it was hella slow...
Im runnin Spoon header with test pipe, bigger b-pipe,N1 exhaust
I haven't bypass secondary O2 sensor yet
is it Bcuz of the Sec O2 sensor? or I need to do something for the
OBD I ECU for my car?
thankx !
Han.
ps.my car is 99'R
pss.thankx to Dropspeed for the ECU
Old Nov 23, 2002 | 05:05 PM
UNVMYR's Avatar
Default Re: havin problem with JDM ECU (DJHan)
I think the Jdm ecu is obd2,and secondly it only reads from one o2,in wich its located right after the collecter on the header.Keep in mind the jdm ecu runs really rich and you might need some tuening to take full advantage of it, depending on what yer set up is.The jdm ecu seems to be a good all round ecu to use for a mild set up.
btw i have no complants with my jdm ecu and motor stock performance.
[Modified by UNVMYR, 2:06 AM 11/24/2002]
Old Nov 23, 2002 | 05:15 PM
MiraiZ's Avatar
I would have stuck with the USDM ecu...JDM ECU does not make it better, its optimized for use with 96+ octane gas, so it probably senses whatever octane you have and has compensated for it...JDM is not better all of the time!!
Old Nov 23, 2002 | 05:23 PM
UNVMYR's Avatar
Default Re: havin problem with JDM ECU (MiraiZ)
so then all he needs is a little octain booster....and his ecu will work better????
i think theres a little more to it than that.Timming and fuel maps are also differnt
Old Nov 23, 2002 | 05:26 PM
Dave-ROR's Avatar
JDM ECU = OBD2 plugs with OBDI programming. No Secondary O2 is used.
There is a VTEC switch difference (pressure switch?) but I'll let those more informed comment on that one.
Old Nov 23, 2002 | 09:33 PM
MiraiZ's Avatar
Default Re: havin problem with JDM ECU (UNVMYR)
octane booster will never bring 91 up to 96...at any rate, I would have stuck with USDM
Old Nov 23, 2002 | 09:42 PM
98cwitr's Avatar
your compression is a good bit lower than JDM that could have something to do with it also. Hum...JDM ECU and turbo...might be a good thing...along with a CTR intake cam.
Old Nov 23, 2002 | 11:15 PM
MiraiZ's Avatar
Default Re: havin problem with JDM ECU (98cwitr)
what???...JDM ECU will NOT work with turbo dude!!...your just beggin to blow your engine if you do that!
Old Nov 24, 2002 | 02:57 AM
DJHan's Avatar
hum... could you plz tell me what did you change or whats your modification
for your JDM ecu? (ex.ignition timin or something)
true..... but Bcuz of that JDM ecu gonna hurt my perfomance that BAD?(Hella slow)
thank you guys
Han.
ps.Im feedin my car with 94Octane
blkboyan
Oct 16, 2006 01:45 PM
hondachris1994
Feb 28, 2006 06:44 PM
im_poor
Jul 1, 2004 07:13 PM
